If the bike starts when it is in gear that would indicate that the clutch switch is sticking/broken? It is located between the clutch lever and the clutch lever assembly, normally a plastic bullet shaped switch with a switch that is depressed when the clutch lever is not engaged and released when the clutch lever is pulled in. The not shifting could be down to the chain not adjusted for freeplay correctly, also lub the gear change shaft. If the chain is adjusted then check freeplay on the clutch lever normally about 10mm, but check with your handbook.
