SOURCE: is my Hitachi 61uwx10b ultravision hd ready
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
SOURCE: Toshiba 51H84 Television Questions
Yes you will need a converter regardless as the signal on this would require a box.
The converter should have a code for the remote ask you cable provder for the code sheet as all converters are diffrent.
Good luck I hope i answered all your questions.
please do rate you answer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: does my toshiba 50h82 have an internal digital converter?
I doubt the model as old as it is will work without a converter.
