Toshiba Satellite M305-S4826 Laptop Logo
charles lemay Posted on Oct 22, 2011
Red concentric lines on the display screen - Toshiba Satellite M305-S4826 Laptop
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Red line on screen above red line screen is distorted below line and it is fine!!
Could be a bad display. If that's the case buy a new TV because the displays are usually more than a new TV itself. God I miss CRT's...
2008 Toshiba 46XF550u flat screen TV.
tried to check first loose connection connector or cold soldered component parts like ic in the X board, which send signal at the screen panel display.if ok, look for the t-con board re seat the lvds cable connector.then if can not get with re seating the t-con board must have bad component parts.
2helpful
I am trying to get the inverse log from 1x10-4.62
I suggest you reformulate the question. If you are doing pH questions, give the pH and we will show you how to get the concentration. Alternatively, give the concentration and we will show you how to obtain the pH. Keep in mind that in the context of pH questions, pH is restricred to the interval [0,14], and that imposes restrictions on the possible values of the concentration.
If c=concentartion, then
pH=-log(c)
This is equivalent to
c=10^(-pH)
Assuming that this is what you want to do (ie. calculate the concentration)
Press [2nd][log] to access the 10^ function
Screen displays 10^(
Enter the change sign [+/-]
Enter the pH value 4.62
Screen displays 10^( -4.62)
Press [=]
The result is 2.398832919E-05. To 3 significant digits the concentartion is c=2.39E-05 mol/L of H+/H3O+ ion
1helpful
RU-42PZ71 displays red lines
No, you will need to call an engineer to check the display, this sounds like a fault either with the main board or very possibly (and most likely) a fault with the screen which would mean replacing the screen
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Concentrator will not line up colors making screen look like 3d
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Red dots and lines on mobile touch screen
You can try a hard reset on your phone by removing the battery for 30 min and then power it on if lines still exists then it is display hardware problem you may need to change display in the phone ...........
Good luck...
Jan 07, 2009 • O2 Xda Atom
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
