For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
- Manually turn ON your device (TV, VCR, Cable Box)
- Press and "HOLD" CODE SEARCH
- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
- Release CODE SEARCH.
- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
- Once the device turns off, press and release ENTER.
- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
- Find codes for each device and brand below.
- Press and "HOLD" CODE SEARCH.
- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
- Enter the three digit code from the TV, VCR or Cable Box code lists.
- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code
You can try using these codes: RCA Codes 000,005,007,008,028, 035,037,054,069
Hope you find this helpful.
Thanks ,
Dennis
