Question about Hitachi 53FDX20B 53" Rear Projection Television
Hitachi 53fdx20b has yellow line on top and bottom an well as blue, all color if off. What is the problem and how much would it cost to get fixed or can I fix it myself?
Posted by Mindy Reed on
Steve Jones
    New Friend:
  • 49 Answers
It sounds like a convergence problem and is typical for many projection sets.
Parts cost would be under 25 dollars.
The repair consists of getting at and replacing two convergence chips and being able to solder is also involved as they have 18 pins each chip.
Let me know your skill level and I would be happy to help.
Posted on Nov 14, 2011
1helpful
My Hitachi has a blue and yellow swirl band at the top and bottom of screen
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes.Than the tv convergence board is dead.The tv convergence board must be replace 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
We have a blue tint and a shadowing effect that makes it appear to have a double on the screen of the same figure / word(s)
This problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or picture look like 3D pictures.The tv convergence board,it dead.Require,must be changes 2 STK convergence ICS and some or all it resistors to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
3helpful
I have the Hitachi 53FDX20B Manufactured in October 2002. It had the convergence problem where the upper left corner was a mixed up coloring and kind of a wavy line that didnt move. Color correction...
You need to replace both of your convergence ICs STK392-110s
use 120s Mats has them 1-800-628-1118 Check Low ohm resistors near ICs 1.8ohms 3.9ohms 2.7ohms etc... RK48 RK50 RK54 RK58 RK60.
On front of convergence board is a blue contact switch this is how you enter convergence pattern R/G/B to adjust convergence,
you can remove Front bottom panel and see the contact switch from front of TV With TV on Press and release then Pattern should come up. When you call Mats ask if they have Convergence Kit that has ICs and resistors in it!
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Hitachi 53fdx20b and it has a wave acrost the top
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
2answers
Color convergence "whacked out"/blue shadow to right side
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2helpful
Color issues with Hitachi 60V715
You likely have a problem with your Optical Engine. It is very expensive to replace and should fix the problem. The lamp cannot cause color issues. You may have dust/dirt contamination in the engine and it could be clean by a servicer or technical person. The blue LCD panel or polarizer may have failed in the engine giving you blue and yellow (lack of blue) type symptoms.
3helpful
3answers
HITACHI 43UWX10B Color Convergence
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Hitachi 53FXD20B Spots with colour
take your tv to a tech and have them check your tv the color module could be the problem or the the convergence module.good luck.
Hitachi 53FDX20B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
