Dremel 400 Xpr Rotary Tool Logo
Karla Hunt Posted on Oct 22, 2011
I need a manual for Dremel 400 series XPR either download or in book form..thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
327
Points
Http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000072942.pdf
I have lost my user's manual for the Dremel 400 xpr Rotary Tool . Can I download it or do I have to purchase it? Thank you, Nancy
you can try going to "dremel.com" and downloading the manual, also there they have a toll free number for tech support which might be able to send manual as a PDF file. Let me know if you have trouble finding it and I will come up with another source
Mastercraft maximum rotary tool icd display is flashing a lock in locked postion
Those digital dremel's are touchy when the get hard use. learn to use it without the display or try to return it regardless if it spins, it's fine.
1helpful
400 XPR - I am trying to remove a saw attachment. The housing cap is completely loosened, but the attachment won't budge. There is no room to use the wrench to9 attempt to loosen it. I have checked the...
The attachment is 'keyed to the motor assembly so it will only go on in one direction. If it was mistakingly forced on in a different manner it can get jammed. Try twisting it from left to right while pulling straight out.
I'm trying out my dremel for the first time, and can't remove the attachment I've been using.
suggest that you go to Dremel.com and download a owners manual for this tool. They also have a toll free tech number for assistance listed there.
How do you attach a wheel cutter to a dremel 400 xpr
Go to Dremel.com and download an owners manual for detailed instructions for this tool.
1helpful
I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
