Lindsey Foxconn n15235 isn't the complete info that is needed. The n15235 is a FCC designation. IF Foxconn 6627-RS2H is the Foxconn motherboard model number, then it's all I need. Is it a Foxconn 6627-RS2H motherboard? Please post in a Comment. If not, do you know what computer it came out of? No? Looking at the motherboard, do you see a model number listed? Look in-between the long white PCI slots, or in the middle of the motherboard, or towards an outside edge. [ If it is a Foxconn 6627-RS2H motherboard, download the User Manual from Foxconn Support. Copy the URL at the end of this clarification, and paste it into your address bar, then press the Enter key. { The plastic front of your computer is the Front Panel. The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header}http://www.foxconnsupport.com/download.a...Lindsey Foxconn n15235 isn't the complete info that is needed. The n15235 is a FCC designation. IF Foxconn 6627-RS2H is the Foxconn motherboard model number, then it's all I need. Is it a Foxconn 6627-RS2H motherboard? Please post in a Comment. If not, do you know what computer it came out of? No? Looking at the motherboard, do you see a model number listed? Look in-between the long white PCI slots, or in the middle of the motherboard, or towards an outside edge. [ If it is a Foxconn 6627-RS2H motherboard, download the User Manual from Foxconn Support. Copy the URL at the end of this clarification, and paste it into your address bar, then press the Enter key. { The plastic front of your computer is the Front Panel. The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header} http://www.foxconnsupport.com/download.aspx?models=en-us0000217&category=C000000001&series=en-us0000002&keywords=&sort=Motherboard%20Manual
You can't post conmments that contain an email address.
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below:
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
wires should be on the tower,were they go should be on the board. there probably know where near the acctual pins,look all over the board with a tourch. forget that here download the manual
you can get all the information you want from this link below:<br /><a href="http://www.cluboc.net/reviews/motherboards/foxconn/755a01/2.htm"><br />http://www.cluboc.net/reviews/motherboards/foxconn/755a01/2.htm</a><br />hope that was helpfull<br /><br />
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
for drivers on M/B FOXCONN N15235 all dirvers go to www.quebex.com, also will include the direct link, and click on model APOLO_48XX and have fun downloading all needed drivers...
