Question about MTX JackHammer JH600 Car Audio Amplifier
Will a jh600 jackhammer amp work without the ebc?
Posted by matt wood on
1 Related Answer
Anonymous
SOURCE: i have an amp tha i bought its a jackhammer JH600
bad bulb or bad ground wire would be my guess
Posted on Mar 03, 2009
Car amp not working
is amp getting power or not could be wires came loose inside speaker box
Stopped working suddenly. No PF lights, no smell. Power light turns on sometimes. Fan turns on. Wired properly. No power to sub/subs.
check the fuse holder an the power holder on the inside of the amp an just to see check ur ground some time they lossen
1helpful
My MTX JH600 works intermittently. I don't hear the fans coming on at all and the amp doesn't seem to get hot. Even at low power the amp will turn off all of a sudden and then boom back on after...
One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
Amp not working blue light is on?
You more than likely have subwoofer(s) wired too low for the amp. It's only stable down to 2 Ohms. You should rewire the sub(s) so that the amp will "see" a 4 or 2 Ohm load.
Why does the amp not turn on or go o protection is it burned ???
either the output amplifier is shorted or the one of the speaker voice coils is
Mtx jh600 feed back in subs light on amp the bolt is blinking
check that the ground wire is bolted tightly to the chassis of the vehicle.
MTX JackHammer JH600 Car Audio Amplifier Logo
Top MTX Car Audio & Video Experts
Pierre Laplante
Steve Sweetleaf
Steve Sweetleaf
 Francisco Mauricio...
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
