Samsung DLP HLT 5087s I got a number fan 1 error. replaced the fan and still gets the same message. do i have to get it cleared by a tech? thanks for your help
White dots that increase in number as time goes by indicates that the DLP chip needs to be replaced. Samsung use to cover this problem under their "white dot" warranty. You can call 1-800-samsung to see if they will repair it. If not, they can give you the closest service center. I would not attempt this repair unless you are a trained tech.
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4] 2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.) 3. Select Tech Menu 4. Select DataSetup 5. Arrow to Clear Counts and press OK 6. Enter Password 1934 7. Arrow to Transfer Belt and press OK.
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
chances are it's the one large fan in the rear of the unit. That's the most common to fail. Easy to do yourself. A $30 part and 20 minutes total to do, unscrewing with a Philips screwdriver, replacing the fan, and putting it back together...
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
