Question about SimpleTech SP-U25/100G 100 GB USB 2.0 Hard Drive
LOOKING FOR THE DRIVER FOR SP-U25/100G HARD DRIVE
Posted by FRED JORDAN on
Brian Sullivan
  • SimpleTech Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if your computer came with a motherboard disk the drivers could be on it
or you could download them
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Posted on Oct 21, 2011
  • Brian Sullivan
    Brian Sullivan Oct 21, 2011
    if these fail to find or fix the problemhttp://majorgeeks.com/DriverMax_d5260.ht... Win7/Vista/XP Driver Max is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
    You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
    Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
    After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
    Just one single computer restart will be required after all drivers are reinstalled!
    DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
    http://download.cnet.com/slimdrivers-fre...
    SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware.
    SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software.
    http://majorgeeks.com/Driver_Magician_Li...
    Driver Magician offers a professional solution for device drivers backup, restoration, update and removal in Windows operating system . It identifies all the hardware in the system, extracts their associated drivers from the hard disk and backs them up to a location of your choice. Then when you format and reinstall/upgrade your operating system, you can restore all the "saved" drivers just as if you had the original driver diskettes in your hands. After one system reboot, your PC will be loaded and running with the required hardware drivers.
    What's more, Driver Magician has a built in database of the latest drivers with the ability to go to the Internet to receive the driver updates. It saves lots of time to find the correct drivers and mature drivers will obviously increase the performance of hardware. If there are unknown devices in your PC, Driver Magician helps you detect them easily and quickly with its built in hardware identifier database.
    You could use either of these to find and fix any hardware driver issue
    hope this helps you
I am looking to purchase a cable that will fit my SimpleTech external hard drive model # SP-U25/120G. Do you know where I can get one?
Try Jaycar or other electronic shop for cables
Take your hard drive along so that the correct USB fitting can be selected
Jan 16, 2016 | SimpleTech Computers & Internet
I am looking for a driver for my Elements WD2500C035 external hard drive!
Go to the WD support website and you can download the drivers there!
Oct 13, 2014 | Computers & Internet
I want to use 1GB Kingston pendrive in windows 98 but it needs a driver. This driver is not available at Kingston site. How to to get it. Pl help. SP GUPTA
1. Verify you are using the service pack that came out just before year 2000. It had improved USB support.
2. USB support was introduced to Windows in Windows 95b, it is possible your drive is a newer USB2 and not 1.1 and may not work in your machine.
Sep 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Solve Your SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Blue lights are not on. Windows 7 does not recognize. I think driver is not installed. Pl advice
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 04, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
USB device not recognized I use windows xp sp 2
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Nov 21, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
XP won't recognize Simpletech Pininfarina 60 GB external hard dr
Make sure you are plugged into a USB2 port and not a low speed port.
You can Bing the device name and more than likely find the drivers at the origanial manf.
Try removing all other external devices before installing the new one.
Re-boot the unit with all disconnected.
After the until has setteled down, plug in your USB drive in the USB2 Port and see if the operating system see's the new installation.
If it is see correctly, then you can install your other devices.
Hope this helps you.
P.S. you may want to look at the jumper setting on the USB drive and set them to default.
Oct 01, 2009 | SimpleTech Pininfarina 60GB External USB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Driver needed for 2gb kingston usb
If it is Win XP with SP1 ( check this - tight click My Computer, click Properties and check if it is Service Pack 1), then you need the latest SP from microsoft (that is SP3).
WinXP not recognizing USB drives, the SP is the most common cause I  have seen. Update to SP3 and it should solve your problem.
HTH,
Deboo
Dec 08, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SimpleTech SP-U25/100G 100 GB USB 2.0 Hard Drive Logo
139 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
