Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Has anyone found a code for the above ViewSonic N3246W LCD TV?. I have just got a Sky+HD box and would like to operate the TV volume with the Sky remote. Thank you in anticipation.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address. 2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT. 3. Using the NUMBER PAD, press the 1 button 4. Press POUND (#). If you entered the address correctly, SAT will flash three times. 5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1. 6. Press the SELECT button on the front panel to close the System Information screen. 7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
in the harmony remote software (7.4.3) go to the device (Bell receiver) under the devices tab and select settings. select the second radio button (adjust power settings) and click next. select "i want to turn this device off when its not in use" and then click next. Continue answering the questions, and then update your harmony remote.
