Uniden CEZAI2998   Phone Logo
L Hudson Posted on Oct 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set line mode - Uniden CEZAI2998 Phone
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Oct 21, 2011
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442339
Points
622693
Press [menu/set] on the base.
Press [select/-] to move the pointer to select DIAL MODE, and
then press [menu/set].
Press [select/+] or [select/-] to select TONE or PULSE
(the initial setting is TONE).
Press [menu/set]. You will hear a confirmation tone.
If you need a manual, you can download a copy here. The instructions above are from page 14.
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Unable to send and receive fax from hp 3050 series
check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
How do I recieve a fax
This question is pretty vague but I will do my best to answer your question.
  • Make sure the fax is plugged into a working phone jack (cable goes to line port on fax if multiple jacks are on fax machine)
  • Set the mode on the fax to auto (if you want fax to automatically answer fax)
  • Set the mode on the fax to manual (if you want to manually tell the fax to pick up the line)
  • Set the mode on the fax to A.M. (if you are using an answer machine, you will need to reference your operators manual for this as each manufacturer uses different settings)
After doing this call you fax line with your cell phone and see if your fax rings then answers (for auto).
Unable to receive fax without picking up hand set - any pointers? We have the setting to Auto
CHECK THE CABLE IS IN THE CORRECT SOCKET AT THE BACK THE CABLE NEEDS TO BE PUT IN THE LINE SOCKET NOT THE TEL SOCKET AND ALSO MAKE SURE THE RX OR RECEIVE MODE IS SET TO FAX MODE IF IT IS JUST A FAX LINE OR TEL FAX MODE FOR USE WITH PHONE.. THE TROUBLE IS USUALY WHEN YOU ARE USING THE FAX ON A LINE USED FOR TEL USE AS WELL..__
Microline 320 Turbo Print Quality Settings
You need to set it in Menu Mode -
Press MODE - the SEL light will go out. The menu light goes on. Press Group and the first line of the menu prints.
Gropu of related items keep pressing group until you see the print mode menu printed - once on the line press SET - keep until the printer prints the setting you want.
After you are finished press MODE to save the changes
2helpful
2answers
CHANGE FONT
The printer can be stuck in double line mode, although it indicates that it is single line mode. Switch between the two modes, pressing " enter" and " clear ", until you are in single line mode again. Now you can change text size again.
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
4answers
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
How to set up 2 fax machines on 1 dedicated line
Set the rx fax to ans on the lowest # of rings and fax mode..Set the tx fax on tel mode..
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
