Fuji FinePix F401 Digital Camera Logo
Question about Fuji FinePix F401 Digital Camera
Fuji finpix f401 power up fault
On power up the green led is lit for approx 1 second but camera refuses to power up. battery appears fully charged reading 3.9 v
Posted by stephen cichocki on
3 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Purple green blurred images
At this age such a fault will not be an economic repair option. Time for the next Camera
Posted on Jun 21, 2007
Anonymous
  • 42 Answers
SOURCE: I can't change the language of my fuji f401.
Download the manual:
http://www.fujifilm.co.uk/media/dContent/mediaCentre/Manuals/f401manual.pdf
Here you see how the menu works, and you can change the language.
Posted on Jul 22, 2009
Anonymous
  • 4090 Answers
SOURCE: fuji finepix 5800 helpppppppp
You dont need the fuji software to view or print. You can use a card reader to retrieve your pics to hard drive and use MS Picture viewer to print from OR get Adobe photoshop.
you can also contact Fujifilmusa com/support for replacement software.
Please rate our help to keep the free service online
Posted on Aug 30, 2009
2helpful
2answers
Hi , My Fuji S9600 has just refused to power-up using batteries, although it still powers-up and operates correctly when i attach the mains PSU adapter. I wonder if this is a common occurrence on this...
A few things here may cause the problem you have First the rechargeable batteries don't hold their charge like alkaline and will drop to zero or near zero voltage in just a few weeks. They may tun on a light but won't have enough power to operate a camera. When this happens you need to charge the batteries possibly twice. Another thing is if the batteries were left in the camera then it's very possible that the contacts down inside the battery compartment are corroded and need cleaning before proper connection can be made. One other thing is that the batteries have been installed out of sequence and I'm including a diagram for this.
Diagram
2helpful
Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
2answers
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
1helpful
Fuji Finepix S3500 camera not recognising fully charged batteries
get a new camera sorry thats an old thing when it runs out its out sorry
Fuji Finepix F401 color keeps going off normal scale
CCD problem. dont use flash mode in outdoor shoot. ur CCD is week .u can send for serv.
fotomohamed,
camera repairs,
stpelagia bldg,vasco-goa. india
Wont take pictures
A manufacturing fault- contact the Fuji support line for instruction to return the camera for replacement
5helpful
2answers
FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
2answers
Fuji Finepix F410 compact loss of images
I have a blue LED problem too....One day the F401 was in its cradle with lights working all right. Next day they were not working. I tried removing and replacing the battery, I also borrowed a cradle, usb cable and mains adapter - but still no LEDS. However, the images upload to the PC as usual, the self timer works, the camera continues to take perfectly good pictures and, as far as I know, the battery is being charged. Any advice/comment will be appreciated if it helps to overcome this problem.
Incidentally, this latest malfunction is a bit annoying since the camera has already had a major CCD fault. I appreciate that digital cameras rely on microelectronics, but it does seem a bit 'throw-away' when you are told by the Fuji technical people that the cost of a possible repair is more than the current worth of the camera.
I have two conventional SLR (Konica TC Autoreflex and a Nikon 601S) both of whcih are working perfectly despite being 27 and 9 years old respectively. So much for progress, eh?!
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you a Fuji Camera Expert? Answer questions, earn points and help others
