Here you go:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CD4QFjAC&url=http%3A%2F%2Fwww.insigniaproducts.com%2Fcms%2Fdocuments%2FNS-2BRDVD_NS-BDLIVE01%2520Firmware%2520Inst%2520Sept%25202010.pdf&ei=jPa0UoT5OuHsyQH-hYAg&usg=AFQjCNG7yN-QGTagpOzSWTwg7olbXNASsQ&sig2=9PdzffHu8vCMJPAki1_XEg&bvm=bv.58187178,d.aWc&cad=rja
Check this link. http://electronicshelponline.blogspot.com/ It has details about the firmware update to many brand TVs, with screen shots. Pull up previous posts there, either by its left side bar,
or view it in Timslide option. Firmware update process to Insigna models are there.
This model, NS-BRDVD, is not Netflix capable. Models NS-BRDVD3, NS-WBRDVD, and NS-BRHTIB are, however. A firmware update may be required when first setting up your player for best functionality.
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
