Scanner error e225 in canon mf4320d - Office Equipment & Supplies
  • 1,833 Answers
This is a common problem and can be corrected by updatingthe firmware to the latest release. The firmware, which must be installed to the printer itself.When you install the firmware from your computer, it gets installed on theprinter and stays internal to the printer. You can download the firmware at the following location: "http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/black_white_laser_multifunction/imageclass_mf4350d#DriversAndSoftware Hope this will help you. Good Luck.
Posted on Oct 20, 2011
    New Friend:
This is Scanner lamp problem. Change Scanner lamp.
Posted on Nov 17, 2012
  • abc_atp1
    abc_atp1 Nov 17, 2012
2 Suggested Answers
surendrababu
  • 88 Answers
SOURCE: when i start with my
E225 error scanner lamp problem your open gas and cling
Posted on Aug 04, 2011
Mike Meder
  • 259 Answers
SOURCE: my canon image class Mf4320d printer shows e225
Main Cause: The scanning lamp (xenon tube) is faulty. The inverter PCB is faulty. The CCD/AP PCB is faulty. The reader controller PCB is faulty.Mode of Detection:0000 A specific signal level cannot be attained by CCD gain correction at power-on.0002 The edge gain correction value changed more than a specific level compared with the correction value used for the preceding sheet.
Posted on Oct 12, 2011
How to resolving canon mf4320 system error e225
Dear
clean the CIS, check the home position sensor(a whit sticker strip under the platen glass) realign it. check the scanner cable.
Thanks.
Dec 11, 2014 | Canon imageCLASS MF4320D
Error system e225
chek the scaner ccd uint. flexable cable is break or ip bord probleem
Jul 27, 2013 | Canon imageCLASS MF4320D
Error E225
imageCLASS MF4320d with error code E225 is the CONTACT IMAGE SENSOR UNIT need to replace. Part Number is FK2-2869-000
Apr 26, 2013 | Cannon Office Equipment & Supplies
Canon mf4320d getting error225
CIS scanner lamp has fault, replace the CIS scanner unit.
Feb 08, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
How to fix system error e100 canon image mf4320d
my printer model no MF4320D
Problems Printer on is Error For Systems error e225
Jun 07, 2011 | Office Equipment & Supplies
Error e225 is displayed on cannon imageclass mf4320d
the error E225 means that the SCANER UNIT is faulty.
You can call for tech for replacement or, if you have the expetise, you can do it your self with a brand new SCANER UNIT from CANON.
Nov 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon MF4320d printer is showing SYSTEM ERROR E225. Kindly suggest a solution.
change the scanner because this massage show when our scanner stop moving or break or jam candition in many case scanner cable create problem those are connected the printer logic card
Sep 21, 2010 | Canon Office Equipment & Supplies
3,336 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
