Convert ntfs to fat32
I have a 2tb seagate and i wanna change it from ntfs to fat32 but dont know how to do so
Posted by Santana lees on
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
windows will ask what format you want to format in NTFS or FAT32
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS?using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Posted on Oct 20, 2011
Aloke Das
  • 1,833 Answers
First of all delete the partition that you wish to convert. This is done by going into Disk Management: right click on My Computer > Manage > Disk Management, which is found under the Storage section. Right click the partition you wish to remove, and click Delete Volume This will erase the partition. Once you have done this, you must re-create the partition. This is done by right clicking on an unallocated region of a disk, and selecting Create Partition. Then click Create Logical Drive. Bear in mind that Windows cannot format a FAT32 partition that is any larger than 32GB. This is the case because FAT32 is terribly inefficient on volumes that are larger than 32GB: fragmentation becomes a serious problem.
Or you can use partition magic software to convert it.
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
How to convert seagate expansion ntfs to fat32
just download this program
http://download.cnet.com/Easeus-Partition-Master-Home-Edition/3000-2248_4-10863346.html?tag=mncol%3bpop&cdlPid=10982635
then format your external hard drive to fat 32... Enjoy..
akuma_ryu21 i hope i helped...
dont forget to rate... thanks..
Apr 27, 2011 | Computers & Internet
My new seagate go flex hard drive is being read by mac but I cannot do any modification, which includes data transfer!!
Most likely the hard drive is formated as NTFS and you will need to download a 3rd party app in order to write to an NTFS file system in Mac OS X, such as Tuxera NTFS or NTFS For Mac OS X
NTFS For Mac OS X http://www.macupdate.com/app/mac/26288/ntfs-for-mac-os-x
Tuxera NTFS For Mac OS X http://www.tuxera.com/products/tuxera-ntfs-for-mac/
Apr 05, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
The parameter is incorrect
which format fat32 or ntfs
make sure its fat32
Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive.
There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type:
convert G: /FS:NTFS.
Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant:
convert G: /FS:NTFS /NoSecurity.
The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it).
hope this helps
Mar 03, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Hi, My Seagate Freeagent 500GB Go HD (Hard Drive) has switched to Raw format. I want to convert it back to NTFS so I can retrieve my data. The drive shows up in My Computer or Computer, but I can not...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 19, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot open the hard drive
Something went wrong in the copy process!! What happened is your file system got corrupted! This can be rectified by trying chkdsk e: /f /r at the command propmt(Start->Run then tyrp cmd and press enter) There is a posissility that your actual hard drive is faulty! Utilities here can help you determine that! http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD try the seatools for windows, because you have an external hard drive! If the test comes back ok then it could be that you need to update your operating system! Also, what file system is the hard drive formatted with, cause the FAT32 isn't as reliable as the NTFS file system, so you might wanna change it to NTFS if its not already!( At the command prompt type convert e: /fs:NTFS and press enter) lemme know how it turns out good luck regards, babb
Apr 14, 2007 | Vantec NexStar-3 External 3.5inch...
Computers & Internet Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
