SOURCE: DUB 2502 550WATT
check you rca in put into the am with out spkr wire connect to amp if protection light still on amp is damage
SOURCE: DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
SOURCE: Audiobahn DUB Mag Audio 2502 Amplifier
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
SOURCE: dub 2502 not in protect mode but not putting out
i dnt knowwat type of speaks u got but ifits low then it cud be tht u have too open up the second coil on ur speakers...dnt sound like the amp since its on & not in protect mode,other than tht i'll recheck the wiring
SOURCE: i have a dub audio
Despite the fact that they claim that the amplifier is 500 watt RMS if you look at the fuse it has on it, which should be one 30Amp fuse it means that the max that you might get out of this amplifier is 300 watt RMS. So an 8 Gauge cable will be more than enough for it. However, saying that, using a 4 gauge cable will not harm it in any way. what you should check before buying a 4 gauge cable is if it will actually fit in the allocated 12V terminal. Respectfully dreamsystems
Testimonial: "awsome help"
