ERROR PADA KEDUA BLOK REKAMAN PADA POSISI REKAMAN HDD TIBA2 SECARA OTOMATIS TAMPILAN LCD MUNCUL PINDAHAN KE SD CARD BERLANGSUNG SEBALIKNYA DARI CARD SD PINDAH KE POSISI HDD,KETIKA SAYA FORMAT HDD DALAM PROSES FORMAT SECARA OTOMATIS BERPINDAH KE POSISI FOTO CARD SD,BERLANGSUNG TERUS KETIKA KAMERA SAYA ON TDK BISA TETAP PADA POSISI REKAM HDD MAUPUN PADA POSISI CARD SD POSISI FOTO,MOHON KEBIJAKAN SOLUSINYA KAMERA JVC EVERIO GZHD7 3CCD FULL HD HYBRID 1920 X 1080 60GB,TRIMKS
SOURCE: HDD error
I got the same HDD error on mine also. I removed the zif drive from the camcorder and checked it with an external zif hd adapter and the hard drive was good. I emailed JVC and asked them what is wrong with it they said to just mail it in for repair. I think it has to do with deleting the original hidden files and folders that were factory installed because when I checked the hard drive for folders it didn't have any in it(mistakenly deleted or moved). From what I have read from the manual you are not suppose to change folder names or delete hidden files. Hope this post helps you out a little. If you figure any thing else out post more info. Thanks.
SOURCE: JVC EVERIO CAMECORDER
Have you recently added an SD card? My Everio was doing the same thing. I found out a co-worker had added a new SD card with more memory. In looking at the user guide, the card was not listed as one that was "guaranteed compatible". I removed the new card and the camera is back to starting up fast and no HDD error. Even though I was not storing data to the SD, it was apparently causing data access problems for the HDD.
SOURCE: My JVC Everio Camcoder keeps saying HDD Error!
reformat your hard drive. That way it will correct the error or flag it as a bad sector.
SOURCE: lost the disks that came with hybrid everio(JVC) 30gb
You can go to the cybelink website and download a trial copy of the software that came with the camcorder. The software is ; Cyberlink Power Cinema, Power Directer, and Power Producer. The camcorder's format is also recognizable by Mac. Or if you dont want ot eventually buy the new software you can manually change the file extension of you movies off the camcorder to .mpg to view back your video using windows media player. Until you get editing software, you would not be able to edit your movies. Adobe Premier Elements 4 works fine with .mov files and Final cut pro.
SOURCE: My hdd is full and I want to record on a 16GB SD
few, if any, SD cards larger than 2GB are SDIO compliant. Most cameras which take SD require SDIO-compliant media. Try a branded card (eg Samsung, Kingston) which is certified SDIO media.
