These binoculars have a 10 yr warranty, so you may contact steiner (http://www.steiner-binoculars.com/) for repair for a nominal charge, however there is an easy fix: You'll need a small (about 1/4 in) screw driver.
1. remove the objective lens protector. This is the small metal piece on the binocular side that is loose, opposite from the eyepiece(part you look through). It appears impossible to "pop" loose from the outside, but if you slip your finger inside(try not to smudge the lense), you'll feel a significant ridge. You may be able to pull / pop it off with your finger, or a small handle.
2. Tighten the screw that is now exposed. Do not overtighten, just a little tighter than what it takes to keep it from "falling" on its own weight.
3. Pop the lens protector back on the object lens.
