Http://www.jordansmanuals.com/ServiceManuals%5CLG%5CWashing%5CWF452C%5CWF-452C%20Service%20Manual.pdf
check manual under trouble shooting
covers most fuzzy logic machines
SOURCE: A top loader L G
P.E means Pressure Switch error. Either the small pipe is clogged or the Pressure Switch is faulty.
Check the following on the Pressure Switch:
- Clogged Pipe?
- Loose connections on Pressure Switch?
If these are fine, and it is giving you the same problem, then I'd suggest replacing the pressure switch. It is not an expensive part at all. See attached pictue of a Pressure Switch example.
Hope it helps :-)
* A Four Thumbs up and a neat Testimonial if this helped you
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
