Siemens SpeedStream 4200 (13A4200001) Bridge Logo
john bottomley Posted on Oct 18, 2011
.speedstream 4200 connections from4200 to computer
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on Aug 27, 2007
SOURCE: speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
A
Anonymous
  • Posted on Aug 26, 2008
SOURCE: Full Bridge Seimens 4200 Speedstream modem for use with Netgear WGR614 Wireless Router
mamaguevos
Anonymous
  • 176 Answers
  • Posted on Jan 05, 2009
SOURCE: can't get a wireless router to work with a speedstream 4200
From the telephone outlet the dsl line (telephone line) connects to the dsl jack of the Speedstrem 4200 DSL Modem.
From the modems open port you connect one Cat5 network cable into the port (in back) of the Belkin N Wireless router.
For wireless internet connection to begin you must also do a wireless set-up on the software side of the Belkin router or through their web interface.
Anonymous
  • Posted on Feb 20, 2009
SOURCE: speedstream 4200
The ethernet light should not blink at all. The first thing to try is a new ethernet cable. If the problem still persists, then you need to check with your internet provider.
Storm608
Anonymous
  • 70 Answers
  • Posted on Jul 25, 2009
SOURCE: No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username ([email protected]) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
SPEEDSTREAM 4200 MODEM CONNECTED TO WRT54G ROUTER WIRELESS DONT
turn on the wireless option in the router...
plug your computer into the router type in
192.168.1.1
username: admin
Password: public
go to wireless tab
turn it on
END!
P.S.
Also you have to be in range!
Speedstream 4200 gaming issues
dude i have the same problem but the only wany u can fix that is getting a new one because your NAT is set to Struct and to play some of the games like Halo 3, Saints Row 2, and other 360 games you need to have it set to open.....
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
2answers
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Siemens 4200
You cant connect 2 computers without any additional equipment. U can go for router to connect more computers.
Take care
Setup Siemens 4200
u need to get an installncd from them or at least the manual install setting so that you can manually configure your computer.
2answers
Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Speedstream modem 4200
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
