Question about Bunn 10 Cup Home Coffee Brewer
My Bunn bx-b coffee maker has no power / lights
Posted by grahamz4 on
5 Related Answers
atbsmmom
  • 189 Answers
SOURCE: My Bunn BX-B coffee maker
Did you check the switch on the side of the machine(vacation switch) to make sure there is orange/red showing? If it is, please give us a call with the model and code date and we can further assist you. Customer Service # is 800-352-2866.
Posted on Jan 18, 2011
Pierre Laplante
  • 2042 Answers
SOURCE: BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Posted on Jan 29, 2008
atbsmmom
  • 189 Answers
SOURCE: Basic Bunn Coffee makers will not light up
Please get the model and date code off the bottom of your brewer. Contact customer service with this information and we will be happy to assist you with this issue.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Need wiring diagram for Bunn BX or GRX coffee
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
atbsmmom
  • 189 Answers
SOURCE: I need a wiring diagram for a Bunn BX coffee maker
Bunn BX-B coffee maker; When plugged into a known good electrical outlet there is no red light. Nothing like a fuse is blown. It made a pot of coffee then nothing. 4 years old.
Check the home panel circuit breaker first. Then plug the brewer in to another outlet. If that doesn't work, there is a chance that the switch is bad. Happens too often on Bunnomatics.
May 20, 2016 | Bunn Coffee Makers & Espresso Machines
My Bunn BX-B coffee maker wont turn on, no light no nothing. Is there a reset switch, or fuse somewhere in it?
Nov 11, 2010 | Bunn 10 Cup Home Coffee Brewer
My bunn bx-b leaks onto counter
Do you have the code date? If the machine 3 years old or less, it will be replaced free of charge for you. Please call 800-352-2866 with the model and code date and customer service will be happy to assist you.
Sep 20, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Need wiring diagram for Bunn BX or GRX coffee maker.
Oct 18, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Oct 18, 2009 | Bunn 10 Cup Home Coffee Brewer
My bunn is causing my breaker to trip
The heating element going bad in the coffee maker.
Mar 17, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn BX-B
I didn't download it since we have a lousy connection but your manual should be available here:
http://common.csnstores.com/common/marketing/bun1002_use_manual.pdf
Despite the '1002' in the URL, it is the link for your model.
Oct 20, 2008 | Bunn NHB Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
399 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
