Question about Texas Instruments TI-84 Plus Calculator
The division row of buttons on my TI-84 don't work. Is there any way to fix it by myself or get it fixed real quick?
Posted by YuJin on
steve novick
    New Friend:
  • 3 Answers
Check button row for small dirt or corner of one button jam into case. use air blower on calc
Posted on Oct 18, 2011
My TI 84 calculator has random symbols that don't erase. none of the buttons really work and the button next to the (2nd) button makes the calculator turn off. however when i turn it back on the...
Reset the calculator by taking out all of the batteries, then hold down the power button for 30 seconds. Replace the batteries and see if it works again. If not, remove all of the batteries again, this time include the backup battery (you'll need a small phillips screwdriver). Wait 5 minutes and reinstall the batteries. Hope it works for you. g.
Sep 06, 2011 | Texas Instruments TI-84 Plus Calculator
Buttons on my TI- 84 Plus Silver Edition are not working. I can turn on the device but the buttons don't seem to work. I can't graph at all, or do anything.
Hi
if you can turn on and then click on the on button and this is the only ket that works then its an hardware problem and it can be fixed
let me know if you want to fix
[email protected]
Jack
Jun 27, 2011 | Texas Instruments TI-84 Plus Silver...
The buttons on my TI-84 do not work
Mooka,
Do you mean that NONE of the buttons work? Not even the on button?
----------------------------- IF NOT ALL BUTTONS HAVE GONE HAYWIRE ------------------------------------
The contacts underneath the keypad are probably amiss. This is a good thing, a common thing, and an easy thing to fix. You can fix this at home, at no cost, and at your leisure. Here's how:
STEP ONE: Get a skinny screwdriver
STEP TWO: Unscrew all the screws on the back of that screwed up device
STEP THREE: Remove the face plate (use a little care)
STEP FOUR: Examine & fix
4a. Dust off
4b. Re-seat all the soft-key contacts that may be off their rockers
4c. Remove any residue
So, if only a few buttons have gone awry then this should work for your TI-84.
Mar 10, 2011 | Texas Instruments TI-84 Plus Silver...
A row of buttons dont work on my calculator, what do i do?
I have run into this before, unfortunately there is a crack in the circuit board under neath the keypad and the only way to fix this is replace the board if it's available through the company.
Mar 04, 2011 | Texas Instruments TI-84 Plus Silver...
Two of my keys seem to be sticking and a whole row of them don't even work. Can i fix this without sending it back? Its a TI 84 Silver Edition.
Surrounding the keys is a removeable cover. It can sometimes become displaced from its standard position. If you look around the edge of the calculator, it clips in. Use your fingernails to remove and replace it.
I had this same problem and simply removed the cover around the keys.
Feb 09, 2011 | Texas Instruments TI-84 Plus Calculator
I jus bought a TI-84. when i turned it on it said RAM cleared. now there's a blinker on the screen. every time i press a button, nothing happens. whats wrong with this brad new calculator
You need to re-install or, update the Ti 84 Plus OS. Since you just bought the calculator it is unusual that it is already to that point of clearing the RAM. You can connect a computer and your Ti 84 calculator together once you downloaded and, installed Ti Connect software on the computer. That way you can use the Ti OS Downloader that comes with Ti Connect software to install the newest Ti 84 Plus OS. Or, if you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84.
Get this problem fixed as quick as you can. You do not want your OS to fail any more than what it already has. If you can not find another calculator to connect too, then you can connect through your computer. You may have a long road ahead of you getting the Ti Connect software and, drivers working right. Just remember to come back to your posting here and, post a comment of what ever is failing. This will notify me right away and, I'll walk you though it if necessary.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 keys are not all working; multiplication and division show up as asterisc and clear does not clear. I have just changed all batteries, including small round one and no change
it could be that the old battery leaked inside and cause this problem in most cases this is the problem.
if you want to fix the Calculator let me know
[email protected]
Jack
Oct 14, 2010 | Texas Instruments TI-84 Plus Calculator
I have a TI-84 plus Silver addition and I have a row of buttons that do not work. Is there anything I can do?
you cant fix it on your own
it could be a fuse or the chip inside
i fix this calculators let me know if you want to fix
[email protected]
Sep 26, 2010 | Texas Instruments TI-84 Plus Silver...
Buttons on far right row of ti-84 plus clear the screen
It seems like a harware problem. I think you shoul have the calculator repaired.
Hope it helps.
Aug 16, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
600 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
