Question about StarTech.com StarView SV211K 2-port KVM Switch
Where is the carburetor float drain on a 2008 linhai aeolus lh150t-12?
Posted by J L Schroeder on
Location of rectifier for 2008 linhai aeolus 300
rectifier usely built onto altenatator
Apr 13, 2015 | Cars & Trucks
Why wont my linhai scooter idle with a taotao scooter carburetor
The carburetor has the wrong idle circuit jet fitted or incorrect idle screw adjustment.
Jan 07, 2015 | Linhai Motorcycles
My 2008 kfx450r wont stay running. when i finally get it started i can pin the throttle wide open for a few seconds but it dies like its not getting fuel please help any info i will take
ALWAYS have a fire extinguisher on hand when working on carburetors.
Open the petcock, (gas valve), and drain 1/2 cup of gas from the tank. Did the fuel flow freely? Is there any water or trash in the cup?
Drain the carburetor. There should be a screw on the lower right side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the float height. The fuel level in the bowl may be low. Bend the tang (in the center of the float) downward to raise the fuel level. EASY, a little bend goes along way.
Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Jul 05, 2009 | 2006 kawasaki KX 450 F
StarTech.com StarView SV211K 2-port KVM Switch Logo
85 people viewed this question
Top StarTech.com Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
