Bosch DLR130K Laser Distance Measurer Logo
tago_ep Posted on Oct 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dlr130 bosch distance measurer, but since yesterday the laser intensity has gone low, i can't see the laser point in the day, and it's not a sunny day it's cloudy actually.. !!!
ZappaNut
Level 3:
  • Master 960 Answers
  • Posted on Oct 18, 2011
ZappaNut
Master
Level 3:
Answers
960
Questions
Helped
308266
Points
2820
Replace the battries .
  • kolodziej_m May 23, 2013
    I replaced batteries but Err is still showing
Bosch GLM80 Laser Distance and Angle Measurer. It will not work. It has been on charge for 5 hours but does not turn on?
Question edited for 'make model (what it is)'.
Question moved from Drills to model category.
Is it new and under warranty?
You say it works, but is doesn't turn on. It can't be both. Details say that once you turn it on, you have to press another button to make it work. Presumably to make sure you don't get the laser in the eye or someone else's eye.
Secondhand and battery worn out?
https://www.google.com/search?q=bosch+glm+80+doesn%27t+turn+on
2helpful
2answers
How to fix a Bosch GLM 250 VF, it keeps on beeping and it doesn't measure
Please make sure that your laser-distance measure is charged properly to start. View it's screen for any listed error codes that could give us a clue to watch the issue is. If the error code hints at restarting the device, then we can move in that direction. If the error isn't revealed from perusing any troubleshooting documentation that comes with your device, then you can reach out to Bosch for repair/replacement help.
Thank you.
Headlight adjustment
AIMING
The procedure outlined here is intended to provide a basic adjustment only.
  1. Park the vehicle on a level surface 25 feet (7.62 meters) from a vertical wall. There must be a horizontal reference point, such as a line on the pavement or another wall, at a right angle to the aiming wall. The fuel tank should be about 1/2 full, tire pressures must be correct and there must be a person in the driver's seat.
  2. Measure the distance from the floor to the center of each headlight. Mark these heights on the wall and draw a line between them.
  3. Measure the horizontal distance from the reference point to the center of each headlight. Make reference marks on the wall so that X marks the center of each headlight.
  4. With the headlights on low beam, the high intensity zone of the light beam should be immediately below the line and about 2 inches to the right of the center of each headlight.
  5. If adjustment is required, remove the grille and use a Phillips screwdriver to turn the adjuster screws.
Error Bosch DLR130 distance measurer
Same problem Err and --- on display. The front lens had become misaligned. Take off front rubber boot, clean lens and replace lens exactly in glue pattern on unit with rounded side facing out. Then holding unit with seated lens upright push rubber boot slowly back on. Very hard at first but push as much in by hand then use a narrow blunt point like the back of a screwdriver handle to press around the edge working it in with slow continuous pressure a quarter inch at a time. It will reseat just take your time and work the high spots. This time was not the batteries, works like new.
Need a manual for a Bosch GLR225
If you're in the US please contact 1-877-Bosch99 (267-2499).
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
http://www.boschtools.com/AboutBoschTools/RequestProductLiterature/Documents/2010%20Catalog%20PDF/2010%20Measuring%20Tools.pdf
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
http://www.engineersupply.com/images/bosch-tools/Bosch_Digital_Distance_Measurer_130k_User_Manual.pdf
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
http://boschtools.com/Service/ContactUs/Pages/default.aspx
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
http://www.analyzemath.com/Geometry_calculators/pythagorean.html
How do I use this tool to measure vertical distances of pipe?
DIRECT THE LASER FROM POINT A <---------TO'------------>POINT B
v
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Top Bosch Measuring Tools & Sensors Experts
goneforever.
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
