Question about CreoScitex EverSmart Jazz+ Flatbed Scanner
Creo eversmart supreme connection (fire Wire) to Mac G4 (Version 9.x.x)failed suddenly without changing options in the application oxygenScan.
Anonymous
SOURCE: creo eversmart supreme Mrk 1 solid red status light
There's either a problem with the power supply or the control board, most likely the control board. Have you tried running the diagnostics yet?
-Ryan
omnicow at gmail dot com
Posted on Feb 12, 2010
New to G4 - how do l install flash player as it keeps telling me not compatiable when l go to install?
depends on your OSX version - you need an older version of flash player for your system, (ver. 10.1.102.64 for Power PC G4)
check here:
Archived Flash Player versions
Most recent version of Flash Player supported Operating system Flash Player Download Center
  • Mac OS X 10.6+ (Intel processor)
Flash Player 10.1.102.64
  • Mac OS X 10.4+ (Power PC processor)
Flash Player 10.3.183.90
  • Mac OS X 10.5
Flash Player 9
  • Mac OS X 10.1-10.3
Flash Player 7
  • Mac Classic
  • (9 and earlier)
http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp_10.1.102.64_and_9.0.289.0_archive.zip Flash Player Help
Feb 11, 2014 | Computers & Internet
Mac g4 desktop cant connect through the built in
Utilise app, you have to reset, should be auto, but sometimes requires manual input.
Aug 23, 2013 | Apple Power Mac G4 Desktop
My ibook g4 track pad works when i move it around the screen but i cannot click a link without having to use the button. how do i fix this.
More than likely, you have the preference for "tap to click" turned off. To fix this:
  1. Go to Applications/SystemPreferences.app or the System Preferences dock icon
  2. Click on the Mouse preference button
  3. Make sure that the checkbox next to "Tap to click" is turned ticked
* If you are using a more recent version of OS X you will instead see a "trackpad" option in System preferences. This is what you want to select to change this setting
Feb 10, 2011 | Apple iBook Mac Notebook
I am trying to install EverSmat Jazz+ on Apple G5 Macintosh. It is connected through RATOC's PCI to FireWire cable, yet the computer doesn't seem to find the scanner at all.
Hi Ralph
What OSX are you running on your Mac G5 and is this an Intel or Power PC? You will find that the Jazz Scanners are only supported up to G4 OSX10.3.9 and no higher.
You may get lucky and find it may work but you will get numerous crashes for no reason and the scanner will also just freeze and you will have problems with the BGCAR application that the scanner application uses.
Sorry cannot be more helpful.
Creo/Kodak Scanner Engineer
Dec 28, 2010 | CreoScitex EverSmart Jazz+ Flatbed Scanner
Creo eversmart supreme Mrk 1 solid red status light
-Ryan
Dec 01, 2009 | Creo Office Equipment & Supplies
When typing it writes number 9 all the time
How often? Can you make it happen on demand?
Acquire any other USB keyboard, and plug it into a USB port on your PowerBook. Use this keyboard for a while. If you don't see the problem, then I suspect some sort of short in your keyboard cable, or perhaps a spill in the keyboard itself.
PowerBook G4 keyboards are very easily replaced, without opening up the laptop itself.
Mar 26, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Creo Scitex Eversmart Jazz bulb / lamp
i have a lot of lamps scitex for this just i am from mexico: [email protected]
Sep 01, 2008 | CreoScitex EverSmart Jazz+ Flatbed Scanner
Can't recognize scsi device - Eversmart II Pro Scanner
UPDATE:
I've now managed to solve this initial problem by installing the relevant extension for the SCSI PCI card, however when I try to launch the scanner software the error message 'No communication with scanner" pops up
I've tried the obvious cables check etc. Any ideas?
Thanks
Jan 17, 2008 | CreoScitex EverSmart Jazz+ Flatbed Scanner
CreoScitex EverSmart Jazz+ Flatbed Scanner Logo
161 people viewed this question
Top Creo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Creo Office Equipment and Supply Expert? Answer questions, earn points and help others
