Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Convergence failure Samsung rear projection television
Posted by Cindy Korbol on
Sonny Berry
  • Samsung Master
  • 8,617 Answers
Usually on your model it might be best to replace the entire deflection board as your model has two STK394-250 ICs and then 12 3.9 ohm fusible resistors that will need to be checked and possibly replaced. If you need further assistance let me know I can assist with getting quality parts and circuit boards.
Posted on Oct 18, 2011
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
Samsung HCM4216W 42 in. Rear Projection Television Not turning on. After opening the back, found out that two resistors (RR402S and RR471S) are very badly burnt. Could that be the problem? I took the...
Sounds like your convergence circuits shorted and took out the resistors. This is fairly common.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Samsung HCM4216W 42" Rear Projection...
Convergence board is bad
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
I have a Samsung HCM5525W that distorts horizontally across the top and bottom after it has been on about 15min. Center of picture is fine.
Symptoms:
Dec 25, 2009 | Samsung HCM5525W 55" Rear Projection...
I have a samsung 42 picture lines top and bottom of screen
DAve1645 is correct!
Symptoms:
  • Screen Looks 3D
  • Colors wont align
You can see some examples here...
Nov 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Samsung HC-P4752W rear projection television We
the convergance amps have failed you need to have them replaced there are 2 of them and some resistors may be affected. the cost of this repair can reach $350.00 depending on the tech you get. this is the most common failure in rear projection TVs. the convergance amps work very hard and are bound to fail. they also have very large heat sinks to keep them cool. heat is the biggest enemy of transistorized ICs.
Feb 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
