Question about Wells F-67 21167 Deep Fryer
I am trying to convert a wells f-67 to three phase and need a wiring diagram please help
Posted by Jeffrey Alan Warren on
Angel Joseph Jr.
  • Wells Expert
  • 684 Answers
Hi there.
You can download Wells F67 electric fryer at http://www.wells-bloomfield.com, it contains conversion of wiring from single phase to three phase, just click the owner's manual on Service and Support page.
Regards.
Posted on Oct 24, 2011
Wells deep fryer 208 volt 3 element. 1 element works other two don't working left to right. Continuity good resistance good. Relay problem?
Sounds like this maybe a three phase unit and you are powering it off on single phase power. Most can be converted to single phase but will draw three times the current and requires some wiring changes. It needs to be on a three section breaker for 3 phase.
Jul 21, 2014 | Kitchen Appliances - Others
I am trying to wire a f67 model converting to three phase need a wiring diagram
Hi there!
You can find conversion manual at www.wellsbloomfield.com.
Regards.
Oct 17, 2011 | Wells F-67 21167 Deep Fryer
How do i wire the 3 phase bus terminal for this fryer what wire goes to what terminal
Hi there!
You can find wiring diagram for Wells Fryer at www.wellsbloomfield.com
Regards.
Oct 05, 2011 | Wells F-67 21167 Deep Fryer
HELLO , i have a Powcon 300 SM i have understood how to change from 460 volt to 230 volt three phase but i can not figure out how to change the whole machine over to single phase 240 ...
Look for a "Phase Converter" at Harbor Freight or look in You Tube for info on building one. If you have a lot of welding to do, I would get a better quality converter than they have at HF.
Nov 29, 2017 | Computers & Internet
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
Jul 24, 2010 | Electric 1HP Century Single Phase Extra...
Converting from three phase to single phase
I have 3phase blue seal electric fryer how can it be converted to single phase please? i have been toild it can and it will take 45amp fuse. please advice.
May 07, 2009 | Kitchen Appliances - Others
Just bought new wells deep fyer # F-67
i had an electrician look at it. he told me the unit is wire for 3 phase, my plug is a single phase. he rewire the unit and it working good. problem solve.
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Wiring diagram for wells f-67 deep fryer
OK what I have here is the link directly from wells on this fryer, this is the wiring schematic.
http://www.wellsbloomfield.com/WELLS%20TECH/Wiring%20Diagrams/pdf/307302.pdf
Hope this helps You
please rate me
Feb 09, 2008 | Wells F-67 21167 Deep Fryer
Wells F-67 21167 Deep Fryer Logo
244 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
