6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
You need to find the vacuum leak, this could be the problem. It may be a hose that is dry rotted or cracked and will be hard to see. You can sometimes spray a mixture of water and soap to find the bad hose. It should not be to hard since you know that the sound is coming from the driver side. Feel and grab around the hoses and slide your hand down to feel for any sucking air.
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
you can buy any small compressor, will do the job, it uses very low volume of air. for blowers, paintguns and drills you need high volume compressors. so if the nail gun is all you will use it for, buy an inexpensive compressor and save money. plz rate-bozcro
magnum 5hp
