Question about Acu-Rite Acurite Wireless Weather Thermometer 604
My acurite 00754W2 thermometer is not showing the outside temperature or connecting to the outside sensor?
Posted by joshrobin749 on
Terry Clark
    New Friend:
Outside temp
Posted on May 09, 2013
1 Related Answer
Marcus Wirkus
SOURCE: I have an Acurite 822-RX thermometer that shows HH
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Posted on Dec 18, 2011
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Oct 02, 2018 | Acu-Rite Acurite Wireless Weather...
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Jul 19, 2012 | Acu-Rite Acurite Wireless Indooroutdoor...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
4,006 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
David Gust
ray gallant
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
