Question about Onkyo HTR500 Receiver
Trying to connect iPod to onkyo ht-rc330 receiver but I only get audio. I don't get a picture.
Posted by Kristy carruth on
Eran
    New Friend:
I have the same problem, anyone slove it?
Posted on Nov 20, 2011
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
Simple question (if you know the answer). Can an outside TV antenna be connected to an Onkyo HT-RC460 receiver, and if it can, how is it done?
Hi Don, No, It does not have a built in TV tuner. The F connector the rear is for an FM radio antenna. Thank you, Onkyo USA
Sep 15, 2016 | Onkyo Audio Players & Recorders
My Onkyo HT-RC330 does not play audio out my speakers all of a sudden ?
Hello Billy, I would advise to try a factory reset of the unit. After the reset see if you are getting test tones out of your speakers in the level calibration menu. If you are not then the receiver would have to go in for service. Thanks, FJD
May 01, 2016 | Onkyo Audio Players & Recorders
Hook up worked a while and now shuts on and off all the time. Why? And how do we fix.
Unwire the receiver completely. Then rewire, ensuring that the speakers wires are correct. Make sure that the main power cord is properly connected. If problem persists, upgrade to new (and better) receiver.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Apr 01, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
Getting rid of captioned
"Captioned' from what video source(s)? Receivers don't create captions. Video sources or the monitor control that.
http://www.retrevo.com/support/Onkyo-HT-RC160-Receivers-manual/id/23462bh031/t/2/
Oct 27, 2011 | Onkyo HT-RC160
I am using Onkyo HT-R320 for past 6 years. It was working fine and i connected via digital cable. suddenly i couldnt hear the audio, but the video is working fine. i verified all the setting (audio select...
I don't have a fix but I think the general explanation that could explain both issues would be that the memory for your settings isn't being retained. Check to see if the digital audio source you're having trouble hearing still has its input assigned to it. I'm thinking all your settings go back to 'factory' when you turn it off.
See this entry:
http://www.fixya.com/support/t3692493-onkyo_receiver_memory_power_backup_not
Page 36 of the manual discusses the Memory Preservation theory.
http://www.retrevo.com/support/Onkyo-HT-R320-Receivers-manual/id/367dj085/t/2/
You COULD also try a forced microcomputer reset once just to see if that resolves the issue (same page).
Jul 12, 2011 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
355 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
