SOURCE: games installation
look for the crack file containing on your cd disc1 (if it has cd disc2). copy it and overwrite to the folder of the game located at the program files. click the icon game on your desktop and it should be working.
if still didnt work and it has no crack file then you should have a virtual drive. does the game playable whenever a cd is inserted? install a DAEMON TOOLS or ALCOHOL 120% on your computer.
ask me you need a help and pls dont forget to rate my solution. thanks!
cheers
CHARCOIS
SOURCE: Trying to install C&C 3 tiberium wars disk error
Are you using an iso mounting program like alcohoal or iso buster, or Nero Iso, it sounds like you are having a problem with failing to unmount some virtual drives, otherwis it wouldn't be up to G, how many drives are in the case. click on my computer and tell me what drives you see that you don't physically have. Unmount the ones you arent using and it should default back to :D, or E, if you have 2 dvd drives
SOURCE: i do dot have installer key coment & concuer
By Beber :) First Decade:2SRR-T77D-WK2C-AEMI-RROR===Tiberium Sun: 011656-054475-265652-4285==Red Alert 2:020753-382048-832797-1403 Yuri: 043930-288237-966022-4511===Renegade:056894-929488-118387-9679 ===Generals:1234-1234567-1234567-6455 == Zero Hour: PWTT-SYTN-KAXX-33TF-AM38 By Beber :)
it should work..
SOURCE: registration code for command and conquer tiberium
hi
ELFX-APRK-E7V8-Y1B5-1911 OR HKM5-YD73-72H6-B273-6FLT OR F4XF-8ZQF-LSZN-SGRK-VL6J OR ALL4-FAPZ-9BG9-WYDB-KAUG
it should work..
