Question about Palm Vx Handheld
I have fitted new rear pad to my vx and now hubs are heating up could the hand brake need backing off,thankyou colin
I have a 83 Bronco 351w I am doing the brakes and the passenger side rotor needs to be replaced can someone walk me through this thanks
Personally I would replace both rotors to prevent a future brake imbalance.
* chock rear wheels, raise front of vehicle and place on stands.
* remove wheels, remove brake calliper and bracket assemblies.
* remove bearing hubs from axles, via removal of bearing adjustment nut
*remove hub seals, clean and inspect bearings, repack with HT bearing grease.
* the brake rotor bolts to the rear of the hub, you will have to remove and replace rotor to hubs, make sure all bolts are thread locked with loctite 263 and tensioned to spec.
* pack hub with grease, install seals, fitt hub assembly and adjust wheel bearing preload, install new split pins.
* fitt brake calliper and brackets, fit new brake pads,
* fitt wheels lower vehicle, test brake for function
Hope this helps..
Aug 02, 2016 | Cars & Trucks
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Jan 25, 2011 | 2007 Toyota Camry
Replaced rear brake pads and now there is a burnt rubber smell. Brakes getting really hot and smoking
it is really common for the rear caliper slides to become stiff or frozen. The caliper should slide back and forth with little effort. If it doesn't than make sure the slides are free and lubricated.
If you had a difficult time installing the new pads into the bracket than that could also be the problem. The pads should fit into the bracket with little effort and feel loose once installed. If they don't than remove the shims and clean the rust from under them. Then reinstall the shims and see if the pads slide a little easier in the brackets.
Lastly make sure you didn't pinch or twist the rubber brake hoses.
Another thought is to remove the caliper from the bracket and try to spin the rotor/hub by hand. Maybe the e-brake shoes are causing the problem?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 27, 2010 | 2000 GMC Jimmy
How do I get the caliper to fit back over the new pads, those being obviously thicker because they are new. I can't figure out how to get the cylinder on the caliper compressed to fit over the new pads. My...
the pistons on the rear brake calipers on many modern cars screw in and out unlike the front caliper pistons that just slide in and out.This is due to the handbrake using the rear calipers for handbrake operation. A special tool is normally required that screws the pistons back in so that you can fit the new pads. On many cars one side will be a left hand thread and the other a right hand thread. Some cars will be the same thread. These rear pistons will not just push in. Good luck.
Nov 07, 2010 | Scion xA Cars & Trucks
Replace rear brake pads
Rear disc brake pads offer better performance and are not as affected by moisture like conventional brake shoe style brakes are. Rear disc brakes are similar to front disc brakes. The main difference is that rear disc brake systems must incorporate the emergency brake system. There are two methods widely used for the emergency brake with rear disc systems. The first system is a brake shoe inside the brake disc that is actuated by the emergency brake lever. The second is a screw style actuator inside the brake caliper. When activated the brake pads are forced into the brake disc and held tightly by the emergency brake lever.
READ COMPLETELY BEFORE STARTING
Step 1 - Identify Rear Disc Brake Components
rear_brake_pads.jpg Rear disc brake assembly includes; rear brake disc, rear brake pads, brake caliper mount and a caliper mounting screw. (Note: Some vehicles do not have the rotor mounting screw.)
Step 2 - Removing the Rear Brake Caliper Mount Bolts
rear_brake_pads_2.jpg To replace rear brake pads and rotors the rear brake caliper needs to be removed. First loosen the rear brake caliper mount bolts and remove them. Turn counter clockwise.
Step 3 - Lift Rear Brake Caliper from The Caliper Mount
rear_brake_pads_3.jpg After the caliper mount bolts have been removed, gently lift the brake caliper from the caliper mount. Inspect the caliper slides; they should move freely in the caliper mount. Remove rear brake pads and hardware.
Step 4 - Removing Caliper Mount Bolts
rear_brake_pads_4.jpg With a socket wrench or other appropriate removal tool, loosen the rear brake caliper mounting bolts. Remove bolts and lift the caliper mount and remove it from the vehicle. Remove the retaining screw from the disc mounting hole. Tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub holding on tightly, using both hands. You do not want to drop the rotor.
Step 5 - Removing Rear Brake Rotor
rear_brake_rotor.jpg Remove the retaining screw from the disc mounting hole, tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub, hold on using both hands and do not drop.
Step 6 - Install New Brake Rotor
rear_brake_rotor_2.jpg Check the new rotor against the old brake rotor to make sure they are the same size. Clean the mating surface on the wheel hub before the new brake rotor is installed. Reinstall rotor retainer screw.
Step 7 - Reset Rear Brake Caliper
rear_brakes_7.jpg Before new brake pads can be installed, the rear brake caliper must be reset. The reset tool winds the piston back into position so the new brake pads will fit. This style of brake caliper will not compress with a clamp tool; it can only be reset with the proper reset tool.
Step 8 - Reinstall Rear Caliper Mount and Install New Rear Brake Pads
rear_brake_rotor_3.jpg After the caliper has been reset, reinstall caliper mounting bolts and make sure the bolts are tight. Then match up the old brake pads to the new brake pads. They should be exactly the same except, of course; the old ones will be worn out. Check the new brake pads for proper fit and install any brake hardware that is required.
Step 9 - Remount Rear Brake Caliper
rear_brake_rotor_4.jpg Reinstall the brake caliper, align brake pad hardware and reinstall caliper mounting bolts. (Note: align the rear peg of the brake pad to the groove in the caliper piston.) Recheck and retighten all caliper and caliper mount bolts. Bleed brake system to relieve any air in the system. Before driving the vehicle, push the brake pedal down and let it up slowly. This operation forces the brake pads to travel to the brake rotors. DO NOT DRIVE VEHICLE until proper brake pedal operation resumes. When test driving vehicle listen for any unusual noises during the operation of the brakes.
WARNING! Always have the vehicle under inspection on level ground, in park with the emergency brake on. Always wear protective eyewear, gloves and necessary clothing before inspection or work begins. Never crank an engine over when anyone is near the battery or engine. Always have an operational fire extinguisher close by, obey all first aid instructions in the event of an injury. Never stand in front or behind a vehicle when cranked over or running. When engine is cranked over keep hands and clothing away from rotating components. Never move a car without proper brake pedal operation.
Jun 01, 2010 | 1995 Saab 900
Brake rotors need to be resurfaced,explain best way to remove rotors from vehicle.
front ones remove wire clip remove bolts from caliper hang caliper out of way remove pads remove 2 bolts from pad carrier put to one side remove 2 disc retaining bolts remove disc may need hammer clean hub flange with wire brush fit new disc clean pad carrier and refit fit new pads put some copper grease on back of pads push in caliper piston slowly using large grips or g clamp fit and secure caliper pump up brake pedal check brake fluid level do other side for rear brakes see my solutions
Dec 01, 2009 | 1999 Volvo S80
Rear brake disc needs replacing
with car on stands use punch to remove pad retaining pins pull out pads can be tight remove 2 calliper retaining bolts move calliper away from disc remove disc retaining bolts remove disc check hand brake shoes and clean look for adjuster between shoes if it has one back it of some models just have hand brake cabel adjustment clean and fit new disc secure adjust hand brake shoes using screw driver through wheel bolt hole clean refit calliper slowley push back calliper pistons fit new pads refit retaining pins do other side pump up brake pedal check and adjust handbrake if neededcheck brake fluid level
Oct 20, 2009 | 2001 Volvo S80
I'm fitting new braks pads to the rear. How do I
with the help of another person, you have to pull the spring back with one person and attach it yourself
Jun 17, 2009 | 1998 Ford Explorer
How to change back brakes? I can't get the brake cylinder to go in.
Do you mean back brake pads or the back brake callipers?
To change pads you need to use a rear brake pads changing tool to screw in the calliper piston or if you are experienced enough you could screw in the calliper with a two mm thick piece of metal sheeting that fits into the grove of the piston.
If you need to replace the whole calliper remove the hand brake cable first and clamp the flexible brake hose remove brake hose, remove the callier with cylinder and then remove the calliper holder. fit new holder pads and locks and the calliper with the piston and the brake hose and the hand brake cable. Bleed the brakes. Mike
Apr 26, 2009 | 2001 Volkswagen Beetle
1999 Chev Blazer 6cyl 4.3L 4WD Rear Brake assy - I have replaced 2 Brake Pads and Rotor. After replacing and a test drive... Its making a scrapeing noise and now the rotor is extreamly hot and descolored....
I replaced the rotors and pads on my right hand drive Blazer and had the same problem ,dont worry in a couple of days normal running the pressure goes away and you dont get the heat problem.
Its just the new pads bedding in.
J.C.
U.K.
Jul 17, 2008 | 1999 Chevrolet Blazer
Palm Vx Handheld Logo
44 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
