The stator is the series of copper windings inside the generator (does not move,). The stator will have several pairs of leads connected to the control panel. The rotor also has winding however is the center revolving shaft. The rotor creates a magnet that excites the stator. The rotor could be brush type having two or more rings where carbon brushes make contact or brushless having built-in diodes and voltage regulator (some not all). You can obtain resistance reading from your dealer to test the windings in the stator. You can easily test the brush type rotor by applying 12v (one or two amp) dc to the rings and test for good magnet at metal part of rotor ( use thin metal blade). Good luck
