nabiscoworld.com Logo
A
Anonymous Posted on Jul 31, 2017
Why did you stop using the wax wrapped stack pack? the crackers were much fresher then. I have brought numerous boxes from the store to find them already stale. My mom bought the wax wrapped stack pack in the 1950's. why change something if there is nothing wrong with the packaging in the first place. i am very unhappy with the way the crackers are wrapped today. this is the premium saltine crackers.
john h
Level 3:
Top Expert:
  • nabiscoworld... Master 29,494 Answers
  • Posted on Jul 31, 2017
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559643
Points
193449
Wrong site this is fixya we dont process ,package ,or sell products
2answers
How can i ship fudge to a friend in Maine without it melting? thanks!
Pack it in dry ice. Be sure both the dry ice and the fudge are well wrapped separatly.and insulation material around both. How much dry ice you ask? If you wrap a small chunk of dry ice with several wraps of newspaper it should last quit some time. It sounds like a trial and error problem. Where to buy dry ice? It's hard to find but stores that use it might sell some.
Coleman canoehow do i protect the canoe hull from from fading . iis there a waxing that would be effective?
You could use a product called 303 Protectant (I think that's the right name) every couple of months, and more if you use the canoe, but that would coast maybe $10 each time and I would ask if it is easier to just store it out of the sun, or under a tarp (not wrapped tightly).
You could try a car wax that claims to protect from UV.
Jun 23, 2014 • Boating
How can i wrap a vase so that it won't shatter nor scratch?
The best idea to wrap a vase i to use bubble wrap. You should first of all gather some bubble wrap or some clothes and put them inside the vase so to roughly fill its emptiness. Then wrap a lot of bubble wrap around the vase, both on the sides and on top and bottom, rolling the wrap round and round and fixing it with tape. make sure its well padded and soft on all sides and corners. Then place the vase in a small carton box that fits it entirely and fill the remaining space with more bubble wrap so that the vase won't have enough room to move around. Then close the box well and write FRAGILE in red on the box.
29helpful
Need instructions on how to use Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath -- how long to leave hands/feet in melted wax, how long to leave wax on, what to do after removing wax any...
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
3helpful
2answers
We lost the factory manual. Once the wax is heated please guide us through each step and the duration? Any help would be greatly appreciated. Thank you so very much and God Bless!
My food although in freezer bags and even store wrapped(sealed) will still end up with frost on it how can I stop this from happening?It is a ROPER
its only moisture inside the wrappings freezing,it will stop freezer burn,you could chill it before you freeze it but that means you would have to rewrap every piece of food again with a vacuum sealer.to make the packets airtight.(when we freeze homegrown veg we always vacuum pack it into portions,so it keeps better).
Door lock suddenly does not function when depressing the start/stop button on my Neptune Super Stack SL3 washer-dryer. The locked light is on however. The result is that the washer will not spin or drain.
If you take off the face plate where the knobs are at or if you know how to get to the wax motor you'll find a red solid cable and if you pull this cable it will release the mechanism which is keeping the wax motor engaged
2helpful
What is the proper way to stack wax rings? I hear
You place the plastic sleeve down toward the drain. If that does not seal due to the floor being higher than the drain mount simply add another wax ring minus the plastic sleeve. You can buy wax rings that do not have the plastic sleeve. In lots of cases you have to use 2 wax rings to get a good seal. Make sure you securely tighten the toilet down.
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Top nabiscoworld.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a nabiscoworld.com Computer and Internet Expert? Answer questions, earn points and help others
