Question about Canon CLC 1180 Copier
Solution for canon 1180 clc error code E021 0401
Posted by anil d. kulthe on
Prakash Wairkar
    New Friend:
  • 13 Answers
Most Probably Your Black Color Developing asssembly is overloded with excess black toner and might not be rotating. Check it
Posted on Oct 31, 2011
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
My canon 1180 is E000 0105 error code. please help me
that error is from fixing unit try to reset that error to reset that error press * 2&8 * then select copier then select function then press clear then select erro then press ok then turn off/on the power switch
Dec 09, 2010 | Canon CLC 1180 Copier
Problem for Canon CLC 1180 Copier E-804 0101
• The operation of a fan (indicated by detail code) is faulty. • The CPU PCB is faulty. • The DC driver PCB is faulty
0001 The electrical unit fan (FM8) has stopped to rotate in error check fans for dirt and it is ok
Aug 12, 2010 | Canon CLC 1180 Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1180 Copier Logo
243 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
