iRiver iHP-120 MP3 Player Logo
Question about iRiver iHP-120 MP3 Player
~*-*~ iRiver iHP-120 (20 GB) MP3 Player Logo * Connect * recording * reset * error * hold * remote * repair * manual * display * format * upgrade * screen * transfer * sound * usb * firmware * download * battery * switch * driver AdChoices Better File Sync Software www.AllwaySync.com/promo Synchronize your local, removable, network, USB, flash folders easily. Problem with iRiver iHP-120 (20 GB) MP3 Player My iriver iHP-120 is stuck on the connected screen and has been for ages, my computer recognises it as a drive though.
5 Related Answers
Anonymous
SOURCE: iriver iHP-120
You can get a replecement on Ebay or at Maplins the spec is
In: 100-240V~50-60Hz 360mA
Out: 5V~2A
be careful I once fried an IHP-120 by using the wrong charger. I replaced the battery but taht wasn't the issue. I had it replaced with a IHP-140 and now my old charger has gone too. I got a replacement through the company I bought it from but they have none left.
Posted on Dec 13, 2007
Anonymous
SOURCE: My iriver T10 is not being detected
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at [email protected]
Posted on Jan 15, 2008
Anonymous
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Posted on Jan 25, 2008
Anonymous
SOURCE: mp3 player iriver t10 hard reset
ive got the extact problem hs anyone found a fix for this ?
Posted on May 01, 2008
Anonymous
SOURCE: iriver T10
Somehow the driver went missing. Click on "My Computer" and then click "view system information," then "hardware," then "device manager," then click on iRiver (it'll be there even without the driver) and then it will give you a yes/no option to look for driver software. Obviously, click "yes" but notice that you are also cued to put in a CD "if you have one." I still had the CD. It will search both the CD and online for a driver, but the computer found the driver software on the CD. Make sure you only put the CD in when cued to do so. If you don't have the CD, then contact iRiver about getting a driver download or having them send you a copy of the CD.
Posted on May 13, 2008
Recognization of iriver ihp-120 portable storage device by pc
when you connect your portable storage wait for few minutes to load.
Recording setting
live recording (using mic) can be great depending on the speakers and your position from it .(dj live up close on the speaker can be destorted) your recording setting should be 1/4 up since the dj most likely is full. TRIED NOT TO RIDE THE '0" RECORDING MARK. the bars while recording should be tapping '0'.the mic on the iriver is quite powerful . now if you are using a line in option (this will take out the liveiiness)
I an trying to use the voice recorder on my iHP-120
Press and hold button on left side with red dot (record)... You will see "stand by"...  Press the lowest button on right side (A-B) over and over until "source" is "int Mic"... when you are ready to record, press the left button w/ the red dot short and quick... recording will begin.  When youre ready to stop recording, press middle button (pic of square on it) on right side... that will stop it.
To find your recording, look in the "record" folder under "Audio"
My iHP-120 will not play
i have a 30 gb hd in mine, plus i upgraded the battery..............but in your case can i suggest www.rockbox.org ............boot up in 30 sec or less, pitch control, you can customize your sound to your like... (bass,highs or etc)
IHP-120 MP3
You can download the software from Iriver goto support then to download and select your player. I would recommend re-formatting your player with a program such as swissknife http://www.compuapps.com/download/Swissknife/swissknife.htm in case you've accidentally partition it somehow. It probably wouldn't hurt to run windows scan disc after formatting(right click your player in my computer and select properties then tools then error checking and check th automatically fix errors box.
2answers
Iriver iHP-140 will no longer switch on
I just reccommended a company called avsense you can find there info on the iriver website i sent mine with a wont power up and a bad headphone jack 67 dollars later its perfect again !!!! there adress is 4038clipper ct freemont ca 94538 there phone # is 1-510-445-0188
Used the wrong charger
you should check the battery voltage first before you get it repaired.
Reset button iHP 120
Nope, you're fine, it's just like pressing the reset button on your computer/playstation/whatever. It will just restart the iRiver and once it's restarted everything will be there just like it was before :)
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
Lawrence Oravetz
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
