Electrolux EW1000i Front Load Washer Logo
Question about Electrolux EW1000i Front Load Washer
ELECTROLUX EWF 1282 flashing Start/Pause. Door Locked.
Anonymous
    Brigadier General:
  • 6,277 Answers
Hi- answered on your second posting ;-0) John C
Posted on Oct 15, 2011
EWF 14922 keeps flashing on Pause / Start button. Load finished can't open the door. Have turned it off and on repeatedly. No luck. Pressing pause button won't start it either. Just keeps flashing.
Your washer drain is dirty,have to clean it. YouTube video can help. Just type your made and model and code. It happened to me once,good luck!
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Showing on screen E41
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
How to do with E40 code of Electrolux EWF 1074?
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
E41 - Door open
Possible causes:
Dado
1helpful
I have a Electrolux EWF 1481. The start/pause is flashing and the machine don't start
Good Morning JeanPierre, thank you for allowing me to assist you!
Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the washer on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potentialwiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
2answers
Electrolux EWF 1282 start pause button is flashing wont start a load have reset it no error messages came up have also cleaned the drain filter the manual way underneath the machine still nothing any
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
20helpful
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
The start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
2answers
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
