Question about Canon PowerShot A540 Digital Camera
My A540 Digital Camera will not keep date and time. I replaced all batteries.
CameraR
  • Canon Master
  • 4,738 Answers
Did you also replace the CR1220 clock battery, located behind the tiny slide out door labeled "CR1220" (see this pic)?
Posted on Oct 14, 2011
9helpful
Will not maintain the date/time
Replace the date battery by following the instructions beginning on page 114 of this manual.
3helpful
Cannot get the pictures to keep date and time on them
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
1helpful
All of a sudden it will not turn on. I cleaned everything , replaced batteries, and still nothing. Does the date/time battery have anything to do with it not powering up? I have always had the date/time...
No, the camera would start even without the date/time battery.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
6helpful
Every time I turn on my Canon A540 Powershot I get the black date/time screen. The date/time is all zero (the photo properties default to 1 Jan 1980) and I have to either enter the date/time or press...
Inside the battery compartment, right beside the AA batteries, there's a tiny little door labeled CR1220 (see this picture). Pry the door open with your fingernail, remove the little button battery located there, and take this battery down to your local drugstore to buy a replacement camera clock battery. Remember, it's a "CR1220" battery. It should cost only about $4.
I am trying to get time and date to appear on my pictures taken with cannon powershot A540
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1helpful
My camera wants date enter each time it is turned
Whatever button you have to press after entering all the info, press it an extra time at the end.
4helpful
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Canon powershot a540 won't start
Please go to this link for a detailed solution from Canon on your camera:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=12942
I would have typed it out, but I think you will be able to print it out and keep it this way. Good luck.
6helpful
Date/Time Reset Every Time I Turn the Camera On
Open up the battery door of your camera. There's a little slide drawer labeled CR1220. Use your fingernail or small screwdriver to pry and slide it open. This little button battery runs your camera's clock. Remove and reinstall it to see if that fixes it. If not, time to buy another battery. The CR1220 battery is very common, inexpensive ($2 to 3), and available at most stores (try your local drugstore). Take the old battery with you to the store to make sure you buy the right one.
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
