Zoom H4 Handy Recorder Logo
Anonymous Posted on Oct 14, 2011
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
731
Points
Update H4 firmware to v2.4 then SDHC cards can be formatted and read.
Penetangtech
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Oct 14, 2011
Penetangtech
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
22375
Points
225
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
2helpful
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
4helpful
2answers
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
Top Zoom Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Zoom Music Expert? Answer questions, earn points and help others
