Question about Pioneer PRO-99 TV
Need manual for a pioneer elite pro-99 and pro-730
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Pioneer Elite Pro-99 Power Problem
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Jan 19, 2006
Anonymous
  • 763 Answers
SOURCE: problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Posted on Aug 21, 2008
Anonymous
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Posted on Sep 07, 2008
Anonymous
  • 12 Answers
SOURCE: just got a pioneer elite pro 119 from a buddy of
If you don't mind opening the thing, open it up and follow the power lead inside the TV. Somewhere along the line should be a fuse. I'd start there.
Posted on Oct 06, 2009
Anonymous
SOURCE: pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Posted on Oct 26, 2009
How can I watch Netflix on pioneer elite pro-111fd
You will need to connect a streaming media player to the Pioneer Elite Pro-111FD. This can be your computer (make sure to set the HDMI input to PC, if needed) or a Roku or Fire (either the stick format or the box). Set the TV to the correct HDMI input and then access Netflix on the media player.
The Ethernet port on this TV is only for use with media saved to your local network. The TV cannot directly use the Netflix app or website. See the manual for details on the Home Media Gallery Server features of the Pro-111FD. The manual is available from Pioneer on the product page: https://www.pioneerelectronics.com/PUSA/Home/Plasma/PRO-111FD . The direct link to the manual is currently https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PRO-151FD_OperatingInstructions0905.pdf .
I hope this helps.
Mar 03, 2018 | Pioneer Televison & Video
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Feb 05, 2014 | Pioneer PRO-710HD 64" Rear Projection...
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
NEED OPERATING MANUAL FOR PIONEER ELITE PRO 530 HD TV
both may be a little hard to find anymore, the main problem is dead set and that is bad soldering all over the giant power supply board this set uses.
Sep 02, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer Elite Pro-111HD 50
Ur video ic inverter board is dead.
U need a new video board.
Aug 23, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
Televison & Video Logo
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
