Question about HP Photosmart C7280 Printer
Print from ipad to HP photosmart C7280 - HP Photosmart C7280 Printer
Posted by Roland James on
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: I cannot print C5 envelopes on HP C7280
In page setup manage custom paper sizes. Enter the size of the envelope and save it. In print dialogue box you can find the C5 envelop. Paper size: defined by driver. This should work
Posted on May 08, 2009
Ben Johnson
  • 685 Answers
SOURCE: HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
Posted on Jun 17, 2009
Anonymous
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
Anonymous
  • 460 Answers
SOURCE: Prints extra blank page for every one page of
pls refix your catridge. if problem is not solved then you can check printer logic card.
Posted on Aug 22, 2009
Anonymous
  • 23 Answers
SOURCE: Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Posted on Jan 13, 2010
AirPlay HP Photosmart C7280
Yes you can.
I share a supported link please visit and read guide. I hope solved your issues.
http://support.apple.com/kb/ht4356
Thanks,
HP Printer Support
May 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
HP C7280 will not print with new black cartridge
HP C7280 REPLACED ALL CARTRIDGES - STILL WILL NOT PRINT
Sep 25, 2012 | HP Photosmart C7280 All-in-One Printer
How do i get my hp photosmart c7280 back online i have a print job but says printer is offline - but it is connected
remove and insert the cable in another usb port.if the problem continues change the usb cable and try
Aug 05, 2011 | HP Photosmart C7280 Printer
Printed colors are not the same as document (I
you need to make sure all your ink cartridges are full, if they are, I would take them out and put them back in and rerun alignment
Jun 28, 2010 | HP Photosmart C7280 Printer
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7280 Printer Logo
59 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
