If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
Always unplug a
microwave before removing or installing any bulbs.
You'll need to remove
the outer cover (wrapper) to get to the bulb.
See these links before
proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch halogen types with your bare skin, as the
oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
