Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
I ended up putting the memory card into my printer and it worked a treat....thanks!I ended up putting the memory card into my printer and it worked a treat....thanks!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Plug the USB cord into the USB port in your PC, then plug in your camera, a box should pop up with the option of Import Pictures, click that and choose the photos you want to upload.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
There are a few different ways to upload them. I have found that when I connect the camera to the computer, sometimes I get scrambled photos. When I use a card reader, connected directly into the USB port, I get all good pictures. If I connect the camera OR the card reader to a USB hub, at least half of my pictures get scrambled. I take 3-4 thousand photos in a years time. I was happy to end the problem.
Screenshot or more details needed. This sounds like camera is faulty, but i dont want to believe it. Are we talking about web cam or like photo camera? If web cam, then just get new one from ebay, no point to have headache when they are so cheap on ebay. But if we are talking about photo camera then make sure you have right drivers installed, all usb settings are correct on cam. I mean, some devices are charging via usb and wont let you take photos unless you change usb setting to media transfer mode. Check those. But if photocam does a photoshot but image is blank then you might have a faulty photo cam
see first urs usb cabel is well fitted in urs pc or not or wid camera..... if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader...... but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not.... ask me if it creates more problem.....
i try to upload photos from my nikon coolpix p50 to 'my pictures' by using my usb cord. it always used to work but not now. something pops up that says "please make sure the device is turned on and properly connected to the computer." i used the the same usb cord as before when it worked.
okay ive had my a345 since christams and all has been good until recently when i tryed to upload my pictures. the camera when plugged in will say "checking usb" then it will say "communication error" something will come up and say "choose program to upload photos" and there isnt a program is it because i set my computer back and dont have the cd? i download picasa but it still wont upload.help please.
