SOURCE: cleaning my Sharp CV-10NH
Here is the link to the manufacture site for your manual.
http://www.sharpusa.com/products/TypeManuals/0,1083,217,00.html
SOURCE: New air conditioner turns itself off two minutes after starting
this sounds as if you have an over amping compresser or blower motor......you'll need an amp meter to be sure. as they over amp they heat up and go off on internal protection until they cool back down in which case it may try to run again and again and again and again and again......should I continoue...good luck
SOURCE: My conditioner Sharp CV-P12LX shuts
If you have to reset the plug then its pulling to many amps. If you don't know what else is connected to that particular line (in your breaker box) you might consider using another outlet. Increasing amps. of breaker may not be advisable without consulting an electrician.
SOURCE: i have a sharp cv-10
Window units do produce water in operation but it normally drips to the outside on the ground. If your unit is tilted too much toward the front making it un level the water can drip to the inside. Change the tilt to the outside.
SOURCE: I have a Sharp portable
Most of these devices have condensate pans that need to be emptied. these can and will shutoff the unit when they become full. i would start to look low in the front maybe behind a removable panel. good luck.
