Question about Maytag MER6772 Gemini Electric Kitchen Range
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it feels like it. Please help me
  • Anonymous Oct 13, 2011
    Its a gas oven
Anonymous
  • 2,341 Answers
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Posted on Oct 13, 2011
    That does not work. When I hold the clock button nothing happens. I know it all works because I deal with this everytime the power goes out. I think my keypad is locked out.
  • Anonymous Oct 14, 2011
    hey sorry i took so long to get back to ya....the instruction to unlock the control are quite simple actually,just press and hold the START button for 3 seconds till a tone sounds. I am wondering though why do ya believe its in the Sabbath mode because it say when in Sabbath mode only the very things that ya expect not to work are the only ones that will work...the clock will display the time and the oven light will work&the timer will work....if it were in the Sabbath mode the lights would not work
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
Skip,
The fact that the display is 'ON' confirms you have power.
The displayed info probably is a 'code' for a fault/problem, but you did not provide a brand nor a model. Even if you had, odds are I do not have access to the list of codes & their meanings.
Try unplugging the plug from the wall receptacle. If you cannot reach the power cord next option would be locate the circuit breaker (single pole) which HOPEFULLY is labeled. Either way, try removing / turning OFF power for at least 10-20 seconds! The control's microprocessor may be locked up due to a very short power interruption.
If that does not reset it, I would call service or the manufacture. You can TRY requesting help over the phone FIRST! Good LUCK
Mrs. Robin Adair-Weber, CET
4helpful
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Hello, welcome to FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
How to use sabbath mode on Maytag Gemini electric oven
Hello, Thank You for using FixYa. I will be helping you today.Holding the clock button puts it into sabbath mode.For all the info if you go to maytag website you can put in your model number and look at the owners manual.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 • Ovens
1helpful
5A6 6ATH error message
Hi and Wlecome to FixYa, I am Kelly.
This is the Sabbath mode. Why it even exists is odd in itself.
Hold CLOCK for 3 seconds to disable the Sabbath mode.
This should get it back to normal operation.
Thanks for choosing FixYa,
Kelly
WENT TO SET CLOCK CAME UP WITH 5A6 ON CLOCK SETTING NOW OVEN WILL NOT COME ON
Your range is stuck in SABBATH mode. You should be able to press and hold the clock button for 5 seconds to reset.
42helpful
3answers
5Ab error code for a Maytag Electric Range
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models you simply press and hold the "Clock" button for 5 seconds. These instructions should be in your owner's manual.
If this does not correct the problem for you, please post back with your model number (located on the back of the range or around the oven door opening) so that I may be able to assist you better. I hope this helps you.
17helpful
3answers
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
7helpful
2answers
Sabbath display makes oven inoperable
Hold the clock button "in" for 5 seconds to disable Sabbath mode.
6helpful
4answers
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Maytag MER6772 Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Vernon Taylor
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
