Ok so why you would buy a washer by that brand is really strange stick to common stuff in the mean time here are the codes for that model
Washing Machine Fault Codes
Zanussi Washing Machine Error Codes
Vote 1
Vote 2
Vote 3
Vote 4
Vote 5
Created: Sunday, 29 May 2011 10:43 Last Updated: Tuesday, 02 August 2016 10:26 Hits: 151998
Zanussi Fault Codes
The Zanussi washing machines and washer dryers that these error codes relate to those that use what they call the "EWM1000plus", "EWM2000evo" and "EWM3000new" boards and it's these fault codes that we will cover in this article. These are some of the most common fault codes for Zanussi washing machine models as well as other Electrolux Group produced brands such as AEG, Arthur Martin, Tricity Bendix, John Lewis and Electrolux obviously.
If these fault codes apply to your machine is should have a fascia panel on it like one of those shown below, there are fifteen known variants covering quite literally hundreds of different models sold in the UK and across the EU.
Alpha Rim
Sigma
Club Display
Club Display
Club Display
Delta Display
Delta Display
Delta Display
Delta Display - without selector & button on/off
Alpha Display
Ellipse Panel
Multipanel Built In
Sigma ZK
AEG NexXxT
AEG New
LCD version without selector and on/off switch
LCD version with left selector and on/off button
The error code is displayed as a digital code, exactly as you will see below, you will get a blinking or flashing light on the front of the washing machine.
If it is the latter then you will see a pattern to the flashes if you look closely it will be a series of rapid flashes followed by a pause and then the series of flashes will be repeated, this is the error code being displayed. If you count the number of flashes being given then you use that number to correspond to the fault code, for example, ten flashes would be fault code A, but we will explain how to read the fault code.
Reading The Fault Code On Non-Digital Zanussi Washing Machines
EMW1000
Proceed as follows to read the last alarm condition stored in the EEPROM on the control board.
Irrespective of the type of control board and configuration, turn the programme selector clockwise to the tenth position. See below for details of entering diagnostics mode.
NOTE: These are the engineer codes displayed after entering the configuration/diagnostics mode.
To enter diagnostics:
In the first selector position, the operation of the buttons and the relative Led's is checked; turning the selector knob clockwise activates the diagnostics cycle for the operation of the various components and displays any alarm conditions.
Displaying The Error Code
The alarm is displayed by a repeated flashing sequence of the two LEDs (0.4 seconds ON, 0.4 seconds OFF, with a pause of 2.5 seconds between each sequence).
The buzzer (if fitted) sounds a series of "beeps" in synchronization with the flashing of the LEDs.
"End of cycle" indicator indicates the first digit of the fault code
"Start Pause" indicator shows the second digit of the fault code
These two LEDs are present on all models (though configured in different positions) and flash simultaneously.
Notes:
The first letter of the alarm code "E" (Error) is ignored as it is the same for all alarm codes.
The fault code families are expressed in hexadecimal form. In other words:
A is represented by 10 flashes
B is represented by 11 flashes
F is represented by 15 flashes
Configuration errors are displayed by the flashing of all the LEDs which means that user interface not configured and you will require an engineer to reprogram the electronic controller or replace it. This is not a DIY repair.
Example Of A Fault Code Display
Example: Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
Four flashes of the "End of cycle" indicate the first digit "4" of code E43
Three flashes of the "Start Pause" indicate the second digit, "3" of the code E43
Zanussi Electronic Controller Replacement
Against a number of the fault codes for these machines you will see that we recommend that you get an appliance engineer to do it and that it isn't a DIY repair. The reason for this is that in order to replace many of these electronic modules it is required that the board is programmed and this is beyond the scope of a DIY repair as well as most unskilled people not involved in appliance repairs.
It is also the case that reprogramming these boards can be model specific, due to the particular features used on that washing machine or washer dryer and that incorrect installation and programming will result in a dead board. Due to the high risk of people programming the replacement board incorrectly we will not offer instructions to the general public on how to carry this out, apart from which Electrolux might get a bit upset if we did.
Most of our approved repairers and all Service Force agents will be able to carry out these sorts of repairs for you at a reasonable cost.
If they make a mistake they have to pay for a replacement board, if you make a mistake then it would be you paying for it and it's not worth the risk.
Before you start any investigation of the fault or even remove the lid of your Zanussi washing machine or washer dryer please read and fully understand this article in full and pay particular attention to the safety and information notices at the bottom of this page as they contain extremely important information!
Please try to support our site by buying Zanussi spares from our store here and, if you decide that you really need an engineer please support the local repairers that help make this site possible, you can search for a repairer from this link..
Zanussi Washing Machine Fault Codes
These fault codes are written for washing machine repairers and not for the general public by Electrolux and they assume a certain level of competence on the part of the user in diagnostic routines. We have added some notes to try to assist you in determining the nature of the fault you have but, you will still need to investigate each failure on its own merits. For more help and advice on fault finding on a washing machine please refer to our basic fault finding guide from this link before you begin.
Please check that any Zanussi washing machine spares recommended are suitable for use on your particular model and PNC number. If you are unsure about the suitability of any spare part please ask to ensure that you get the correct spares for your washing machine or washer dryer. Please, don't guess or assume as spares can be altered on a production run with the same model number having several different alternative components used.
Most models with the single control or display (EWM1000) PCB. The EWM2000 PCB is used on the AEG machines and there is very probably a huge crossover in the information between these two.
E11
Difficulty in filling during wash phase
This is usually your basic filling error so the usual should be checked, that the water supply is switched on and then onto the water fill valves.
E13
Water leakage detected
This is only applicable where a leak detection system is fitted.
E21
Difficulties in draining, drain error
Basic drain error, check the drain pump filter is clear and also the drain pump is actually working.
E23
Malfunction of drain pump triac
This refers to the triac that controls the pump function on the main controller.
E24
Sensing circuit of the component (triac) that controls the drain pump faulty
As above.
E33
Incongruous between closure of anti-boiling and 1st level contacts of pressure switch
This is a pressure switch or sensor fault and we would not recommend you attempt to DIY this fault.
E35
Water level too high
Again, water pressure system fault and again, we wouldn't consider this to be a DIY repair.
E36
Sensing circuit of anti-boiling pressure switch faulty
As above.
E37
Sensing circuit of 1st level pressure switch faulty
As above
E39
HV sensing circuit of anti-overflow pressure switch faulty
As Above
E40
Door open, door interlock, wiring or main PCB
Usually a door lock that's faulty.
E41
Door open
Close the door!
E42
Problems with aperture of the door
Pretty much the same as E40 and E41 fault codes.
E43
Problems with the triac which actions the door interlock
Again, this refers to the triac on the electronic controller and you should seek an engineer as it is not a DIY repair.
E44
Door closure sensing circuit faulty
As E40, E41 and E42.
E45
Problems with the sensing circuit of the triac that actions the door interlock
As E43.
E51
Motor power triac short-circuited
Yet again, this refers to the triac on the electronic controller and not a DIY job.
E52
No signal from the motor tachometric generator
Tacho coil on the motor is most probably faulty. This coil reads a magnet as the motor turns to detect the speed that the motor is spinning at and this in turn allows the electronic controller to set the motor to revolve at different speeds for the various program options.
E53
Problems with the sensing circuit of the triac which powers the motor
Another one that is a fault being reported on the electronic controller and not a DIY repair.
E54
Motor relay contacts sticking
As above.
E61
Insufficient heating during washing
Usually a heater failure but possibly the thermostat or NTC temperature sensor or wiring to either.
E62
Overheating during washing
As above only the heater will likely be okay.
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: zanussi zwf 1632 w
hi follow this
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
SOURCE: Zanussi zwf1237w washing machine
I had the same problem my 3 yr old had been playing with the buttons and the whole thing just locked up and displayed ERR no amount of unplugging turning off would fix it.
Till ...........
This discharges the program memory chip and resets to default.
Hope this helps it's not so hard as it sounds just take care with the battery. DON'T put to much heat on it use a screwdriver on the small connections to act as a heatsink.
SOURCE: ZANUSSI ZWF1237W 2 YEARS OLD NOT WORKING
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
