Kodak EasyShare C143 Digital Camera Logo
Anonymous Posted on Oct 13, 2011
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take pictures.
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Oct 13, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14456924
Points
60858
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
My camera seems to be locked on the internal memory no matter how many blank sd cards i put in it keeps saying memory full
You need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format". Follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
1helpful
I put ib a new SD card but the camera wont take a picture..It keeps saying...Internal memory is full
You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
In sert SD card turn on camera. screan shows Memory card refquires formatting, continue and stills reads card needs formatting. put new card in and does the same. Camera does not read card always say card...
Hi halestone26,
I would like to help you out with this problem ,
Please follow the below instructions :-
  1. Make sure that your remove the memory card out of the camera and connect it to your PC via a card reader.
  2. After you connect the memory card , to your pc via a card reader , you should get a removable drive icon relevant to your memory card in your my computer folder.
  3. Then all you need to do , is select format by right clicking on the card , and then when you see the options in format dialog box you need to select the NTFS and FAT32 one at a time and format the memory card and then check if it works with NTFS file system in your memory card or FAT32 file system.
  4. Unless your memory card is damaged , the above solution works 90% of the times.
Hope this helps ..:) Your feed back would be appreciated.
7helpful
3answers
I have a polaroid dvf-720 brand new and trying to record and 2mins and it says memory full? i dont understand,and i have a memory card that says card error,need help or im in trouble with the wife!
Ok so I have the same problem I went out and purchased an SD card...but it doesnt work. So I called Polaroid and you need to purchase a CLASS 6 SD card of 2gb or more for it to work properly...figures it does not say that in the manual.
My camera is stuck on internal pictures and it doesnt read the memory card. Everytime i turn it on it says its on internal memory. Its been like this for 4 months now. How d you fix it ?
Simple..remove the card. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
1helpful
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
When turned on my camera says Internal memory full & I have a memory card already I NEED HELP PLEASE
1helpful
4answers
When i put card in camera it keeps saying reinsert card
You didn't say what camera you are using, check the specs for the camera and see if it can use a 2GB card. If the camera is not able to use that size card it will not "see" it.
Have you tried putting the card in a reader and formatting it on your computer?
If it the computer can't see it, the card may be bad.
1helpful
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Help with memory card saying unable to format
Hi Eric :)
Please try formatting the Memory card using your computer first in the following manner:
>> Insert the memory card into memory card slot / memory card reader
>> Check the drive letter that it has been assigned by the computer
>> Right click on the drive and select Format option
>> Now this is very important.. Select FAT file system from the drop down options (DO NOT select FAT32).
>> Now Format the card and then try formatting the same card in Camera.
Let me know if that works for you.
Regards,
Srinivas
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
