Does the timer advance in timed dry setting or will it not advance no matter where its set??
If it does advance in the timed dry (or air fluff setting) but just does not advavce when dryer is set to autodry setting the problem is going to a poor air flow problem and the lint filter/blower housing should be checked for lint build up also the vent tube should be checked for a blockage
If the timer does not advance at all on any setting ya need to check the wiring of the dryer for a possible burnt wire on the neutral side
GENE
Testimonial: "Although the problem was not resolved, the help was way beyond what was expected. Thanks Gene, for all your professional assistance, it is really appreciated!"
Hey John,
Its possible that a resister that connects inline to the timer advance motor is what the problem, here is a link of what the resister looks like along with the part numberhttp://www.repairclinic.com/PartDetail/R... please note the part number as item number is Repaiclinic's internal part number and the OEM part number is 279872 replacing that resister should resolve the problem and the timer will advance normally...... GENE
Hey John,that resister will be somewhere in the control panel if ya haven't already take a look at the picture in the link to repairclinic and see what it looks like so ya know what your looking for,at least on of the wires from it will connected to the timer so tracing each wire on the the timer should make it easier to find since its covered in taht black shrink wrap is could be pretty hard to find yet again it will be in the control panel somewhere
oh a thing that should make it easier to find it will be a orange wire
let me ask ya a question,what is your exact model number...listed in the question is TEDS840JQ after the JQ is another number,on my parts look up site i use their are 4 models with the TED840JQ and each of those has a additional number at the eand its either 0,1,3,2. Only the model with the 3 at the end is the only one listed as using that resister..if your model number ends in 0,1 or 2 it has no resister yet i know a bad resister will make the timer not advance regardless whether its a brand new timer or not...that's why i said the resister would be the problem but if your model doesn't have a resister i have to mull over the reason why the timer wont advance
Hey John,
i am striving to figure why your timer isn't advancing. If you haven't already tried one thing ya should do is check and see if power is going to the timer motor. to do that use a multimeter set to measure ac volts ancd check on the 2 wires of the timer motor for 120 volts ac when the dryer is running .if ya dont have 120 check and see which part is missing..is the hot side or the neutral side that isn't at the timer motor.
The wire for the timer motor that connects to the BU (blue) terminal is the hot leg..place one meter lead on the the blue wire terminal and the othe meter lead on the a green ground wire and see if 120 volts is coming from the timer to the timer motor
The neutral side can be checked for power to it but it can be tested for continuity,set the meter to check for continuity and check from the wire on the timer marked as TM (timer motor) to the white wire on the connection where the cord connects to and see if it has continuity at all times..this can be done with the dryer off and unplugged .
If you do not have a meter they can be purchased pretty inespensively at HomeDepot,Lowe's for around $15 for a basic model and if ya have a HARBOR FREIGHT in your local area they are $5.00 for a basic model (google harborfreight.com to see if one is near by to ya )
When searching that exact model number i did see a resister on the wire harness to the heat selector switch and i dont know for sure since i can not find a wiring diagram online but i know that wire harness has a blue and violet wire and suspect the blue wire goes on the same exact blue terminal on the timer that is the hot side for the timer motor and would suspect that is the resistor for the timer motor..i can not find the one im thinking of but as i said yesterday whena timer doesnt advance and its a new timer i would highly suspect a resste for the timer motor as the problem
One thing ya could do if you have the wiring diagran for your dryer which usually in the control panel ..ya could scan it if able and post that scan as a picture to photobucket and send me the link for it so i could look at it to see why that timer isnt advancing.
The standard wiring for a timer motor though is blue hot/tm neutral giving 120 volts to the timer motor
i hope some of this will help,
GENE
John, It's supposed to be against the rules for me to post my email here on Fixya and hope they forgive me but i am doing this in a effort to help ya with the dryer i could use form seeing that wiring diagram to help ya ... my email ya can send it to is [email protected]
Hey Jack,,
Thanks i received the wiring diagram,when i see it was wrong onm what colors to check it's----- when on timed dry their should be a constiant power supply to the timer motor via the blue and orange wire, and when on auto dry setting the power is supposed to be from blue and the white wire with the black stripe on it (WB) Now once again the common thing to those is the blue wire..the same blue wire that the wire goes to on that resister on the heat selector switch and i would seriously consider replacing that resister, Their is a wire harness with the plug and the blue and voilet wire the part number for that is 8539893 perhaps though ya might want to check that resister value to see if its good. Tell me if i am wrong but i see the colors of the bands on the resister to be blue,red,red &gold when looking up online the value for that color combo is 6,200 ohms (plus/ minus 5%) i cant tell for sure but it could be blue brown,brown, gold in that case it would be 610 ohms (a mere 10% of the 6.2 thousand) here is what i used to calculate the valueshttp://www.csgnetwork.com/resistcolcalc.... so if the colors are different let me know and ill recalculate the value
Good luck i hope this helps,
GENE
Ps i was in the process of writing this when i got your message asking did i receive it
No Jack their is no need to remove it from the plug to test it just unplug the plug from the switch and place one meter lead on each terminal in the plug to check it...one thing i overlooked before in your previous comment is that ya also had 120 to ground on the TM terminal on the timer motor....What do ya get if ya place one meter lead on TM and the other on BU i would expect 240 which baffles me even more ...i didn't want to say so since it makes absolutely no sense but when i looked at the diagram i read it as 120 one each wire at the timer motor and no neutral...did the original timer ever advance??
i made a small typo before i said when testing the heat selector switch (not the resister) to test for 10 ohms minimum on high setting....i meant check for a minimum of 10 thousand (10K) ohms on high
One last thing to check JAck,and that the heat selector switch itself,unplug that plug and place the 2 meter leads on the terminals on the heate selector switch and when set to the lowest setting it should read 10 ohms maximum and on the high setting it should be 10k minimum,thats about the last thing to check before buying a new dryer. I posted this problem on the experts forum here on FIXYA,to get additional ideas and two other tech's also think the resister will be the problem but now we can rule that out. I also emailed Whirlpool asking about it and as if no response from them ,it drives me crazy trying to figure out whats the problem since its usually sucha easy problem to diagnose...but most dryers are wired to 240 volts ac on the timer motor but just 120 so thats whats got me in a quandrie as to the problem since 240 at the timer motor is so rare way to wire it that way. I will keep think about it (as i have been) but with replacing the timer and the cycling thermostat as i remembered you saying ya already did,and everything else seeming to be good,i am at my wits end. I just got in and have comments in the experts forum and if any one has some in sight on it i'll let ya know after reading them.
Sure does help...it sounds to me like your using a older style analog meter with a needle and not a digital display meter?? i sure don't want ya to waste money on a digital meter but again if ya have a Harbor Freight store in your area,a digital meter is $5.00 but that's ok. To check that switch ya only want to check pin #1 & pin#3 when its set to the lowest heat setting ya should have 10 ohms max. (10 ohms max is continuity basically ) when the switch is set to high their should be a minimum of 10 thousand ohms ,which will be no continuity on a analog meter,on the pins# 1/3 So it sounds as if that heat switch is good since on the low setting it has continuity and on the high setting it does not have continuity (10 thousand ohms or above is hardly what i would call continuity )
Sounds good i will keep plugging away to come up with a answer since its driving me crazy that i can not figure out why the timer isn't advancing and in my 30 years experience as a appliance tech i pride myself on my diagnostic skills and am stumped on this one.
Just purchase a economical digital meter (mine cost $475 and that was on sale down from $600) since i assume you wont be using it that often,at Harbor Freight i would recommend this one,it will do what ya need and not cost too much http://www.harborfreight.com/7-function-...
Have a safe and enjoyable trip
Hey Jack,sorry their is nothing else i can think of...it has been several days since my friends here at Fixya and i chatted about it but we all were in agreement that is was going to the resistor and now along with the timer thats brand new so i am at a loss to figure out why the timer isn't advancing SORRY !!
Thanks for the response. I opened everything, cleaned everything, inspcted all electrical conections. After, everything seems to work - buzzer etc. except the timer does not advance in any temp setting. No change. Any other sugestions ?
Thanks Rick. Could you tell me where this resister is located? I don't see in in my machine.
Sorry! I mean Gene not Rick.
Thanks again. My timer motor is mounted on a control module and the wires from the motor go to the module. I looked all through the back of the control panel and did not see anything that looked like the picture. But I will look again in the morning - had to put the thing back together so wife could dry some clothes.
Looked high and low for in line resister but no luck. My model is TEDS840JQ2 - missed the last "2" on original post if that makes a difference. I also changed out the Cycle Thermostat that anouther source had told me would fix the problem - - NOT! I am at wits end and need a solution since wife recently forgot the dryer was running for hours and without cooldown and auto stop, the house could burn down. Any other thoughts would be appreciated.
Thanks Gene. I saw that resister on the back side of that switch and it looks perfect. I do not know how to photobucket and my scanner does not do JPEG, I have a good scan on PDF format of the electrical diagram I can send if you tell me how to get to you..
Hi Gene. Hope you got the diagram. I do have a meter and nervous about using on live circuits. But I did as you asked and determinmed that I do have 120 from blue conection to ground with power turned on. I do not have continuity between terminal TM and white terminal on the timer modual with power off. I also do not have continuity between TM and the white power cord lead - I wasn't sure what you meant. One motor wire goes to blue (at this terminal there are two blue wires plus motor wire), the other motor wire goes to terminal marked TM - the motor wire is the only wire connected to this terminal. Hope this helps.
One more thing, I have 120 from TM to ground also. thanks.
Hi Gene. You are right on with the colors on the resister - plus, it is a 6200 ohm resister - printed on the back side if the switch. One red band looks a little wider than the other if that makes a difference. Do I need to remove the resister to test it or can I check it in place? Will it just pull out from the switch ? The part (harness and plug) that you refered to, is that the switch with the resister attached ? Seems like we are getting warm! Jack
Yes the timer did work at one time. I was thinking that power came to the moter via blue wire and I saw that current was there. The current would go through the moter and would go to ground via TM-OR or TM-WB. When I went from TM to ground I thought I was just making a path for the current coming in on the blue terminal through the motor. This is all confusing to me. I don't know much about electricity and on the diagram I see timer switch 0,1, 2, and 4 - haven't found 3 yet - all very baffling! When wife lets me have dryer again I'll check out that resister - I see what you mean now about the "plug".
Hi Gene. After dealing with family matters I was able to get back to my dryer problem. Opened her back up again and, assuming I am reading my meter right, that resister measures exactly 6200 ohms. In addition with the unit running, I had current at both the W/B terminal and orange terminal in Timed Dry mode. I also had current at both those terminals in Auto Dry mode. When I say I have current what I mean is I touch my meter red lead to the terminal and touch the black meter lead to a grounding connection(Green) and read 120 on the AC scale on the meter. Do you have any other ideas or should I start shopping for a new dryer ?
I don't know what I am doing on checking the temperatue selection switch. There are four posts at the rear of the switch. Blue wire along with one side of the resister goes to pin 1. The other side of the resister goes to pin 2. And the violet wire goes pin 3. I guess the fourth pin is not used. I cannot figure out what pins to check when selector is at high,medium or low setting. I was assuming that I go from the blue connection (pin 1) to the other two - I get no continuity going from Pin 1 to Pin 2 or Pin 3. when the selector is on high or medium. When on Low temperature setting I get full scale continuity when going from Pin 1 to Pin 3, and nothing going from Pin 1 to Pin 2. Hope this helps. Thanks, Jack
Thanks. I was in a shop this morning and they only had an analog meter that looked worse than the one I have. We do have a Harbor Freight about 20 miles away and also a Best Buy near by. Unfortunately I have to leave town Thursday for about a week. Maybe by then I will have a digital meter and your friends/experts may come up with something else to explore. The rest of today and tomorrow I need to pack up. I hope to be back on Tuesday 10/25. Pick back up than - OK ? thanks, Jack
Thanks. Just got back from Harbor Freight - what a deal for 5 bucks!
Gene. I'm back and with my new digital meter took readings from my pin#1 and pin#3. Got 1.2 on the low heat side. and no reading at all when on the hot setting. Took reading with and without the plug inserted. I'm going to look up the switch and the plug harness and if not too expensive going to change out both. Thanks,
Put in the new switch and harness with no change. Now what ?
