Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Posted on Jul 30, 2013
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
SOURCE: what is the oil to gas ratio for the husqvarna
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Posted on Apr 11, 2010
SOURCE: my husqvarna 125L weed eater will only run with
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
Posted on May 10, 2010
SOURCE: I replace the gas line,fule filter spark plug and
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
I have one of these and had similar symptoms - the fuel line was cracked in several spots. I noticed a very minor gas leak when I inverted it. Replaced the line (there is a kit for this) and the fuel filter - runs fine now.
Posted on Jul 27, 2010
